13th November 14, 11:11 PM
celtic croft great kilt advise
I think I had asked before on this forum or another about great kilts. I keep coming back to celtic croft. I'm looking at their homespun wool/poly blend (loose weave), or the poly viscose. Has anyone had any dealings with either? Are they both washer friendly? Would one keep me warmer than the other (they are both about the same weight (9-10, and 10-11 oz respectively)? I would think the polywool would be warmer, but I'm not familiar with the materials. Cheater pleates, should I? I would think not. Just stretch it out on the ground and get to pleating. Simple enough. And lastly, belt advice. Should I go with a more narrow belt? Like 1.5 inch? 2? 2.5? Lots of questions, I know. I'm looking for advise from the sages.
Eadie of House of Gordon
McGhee of House of MacKay
Turner of House of Lamont
14th November 14, 12:16 AM
I have no experience with either of the two fabrics , however , it's generally a 3 " belt worn with a great kilt .
Cheers , Mike
Mike Montgomery
14th November 14, 04:22 AM
I have the Homespun Macneil (ancient) Great Kilt with cheater pleats. Yes, the cheater pleats are worth it, to me anyways. I don't have the patience (or honestly, the floor space in my apartment) to lay it out completely flat and do the pleating. I haven't worn it enough yet to know about the washer-friendliness (Is there such a word? I digress.). It is a fairly heavyweight fabric. the photo was taken at the Maryland Renaissance Festival, and purposely waited for a cooler day to wear it. As for the belt, the top have hangs enough over it the belt didn't show, so go with what your comfortable with. To me, a wider belt seems more appropriate. I wore a 2" black leather I got from AmeriKilt. I have two contemporary kilts in the homespun wool from Celtic Croft as well. Personally I love them.
"Don't give up what you want most for what you want now."
Just my 2¢ worth.
14th November 14, 09:28 AM
fabrics with wool are warmer than all man made, as a rule, and they also tend to age rather than wear out - a subtle but important difference in the scheme of things.
I think that the width of belt might be influenced by your decision about the cheater pleats. Having tried out a great kilt as a dressing gown I ended up with a sash to secure it before deciding to take scissors to it as it was just not practical in our house.
14th November 14, 09:53 AM
I do appreciate the comments. Reason I ask about the belt is because it's sole purpose it to hold the kilt up, and will not be seen. Except perhaps the buckle. As for the length.. it says 4 yard for a 34" waist. and I'm 34.5 so I guess that would work. But so wouldn't a 5 yard kilt? or more? I have a budget 8 yard kilt that I doubt is actually made with 8 yards. It's probably 7, or 6.5 But still, couldn't I get longer length and just make deeper pleats? Or is that just a bad idea for some reason?
14th November 14, 11:14 AM
Well - the bottom would be alright, as it falls in pleats just fine, but above the belt there is ALL THAT FABRIC, just sloshing around - I found that I was clearing tables as I passed by and catching the furniture with - I think 5 yards - it was too much, even when I made the bottom part longer and put a sash around the top to try to control it all.
A bit of minimalism doesn't go amiss with a great kilt - not when worn indoors, and I suspect that scrub and heather landscapes were not around when the great kilt was being worn, even though they are so common now they are there as a result of modern-ish methods of land management.
Anne the Pleater
14th November 14, 11:48 AM
Anne the Pleater
really? I thought since they are all the same width of fabric (58-60 inches) the amount of top half material would be irrelevant. Sure there is more length (or width on the waist) but its all held up in the back right? I wish I could try these on before buying....
14th November 14, 04:26 PM
A great kilt will have a lot of material above the belt. You can tuck it in for pockets, wear it over your shoulders for warmth and if you are short enough, wear it over your head (I am not short enough). It will give you a big butt. You can also tuck it in for pockets and wear it over one shoulder and pin it. I don't know what a 'kit' consists of but you can just get the yardage and a belt and pin and make your own.
14th November 14, 11:02 PM
Ok, so to re-phrase the question and get back on point: to those that have a great kilt (or have worn them for a day) what size do you recommend? 4, or 5 yard? I already have your opinion pleated, and thank you for your $0.02 It is appreciated.
15th November 14, 04:01 AM
The longer length is for larger waists. I have a 36 inch waist and could easily use a 4 or 4.5 yard kilt. I bought 5 yards because I had the same questions. Since the ends are un-pleated, about a yard, the rest is what ends up pleated. If you get 4 yards that means about 3 yards pleated, probably plenty.
