Results 1 to 2 of 2
    Benning Boy is offline Membership Revoked for repeated rule violations.
    1st February 14
    Tall Grass Prarie, Kansas
    Jocking a Mackie
    I'm having trouble getting my new Mackie balmoral shaped. I've always soaked my berets, rolled them in a towel and wrung the water out, put them one, shaped them, then worn them until dry, or nearly so and have never been disappointed with the result. However, my new Mackie didn't seem to like the treatment. It developed a lot of ripples, or puckers that it didn't have before the treatment. This is the first bonnet I've jocked that had a lining, and I'm wondering if the lining has caused the problem. I didn't want to cut it out before giving the usual process a try, but recall some have recommended it. Should I cut out the lining and start over again?
    I did manage to get the bonnet to set on my head without the dreaded pizza boy look, but I think it would look nicer without the ripples.
    30th September 08
    Cypress, Texas
    "rolled them in a towel and wrung the water out..."
    I think that may have been where you went wrong. When I've "jocked" my Mackie bonnets, I've just given them several brisk spinning tosses in the air to help eliminate a bit of the excess water, then hung them up to dry (per Jock Scot's instructions). Both of mine turned out fine and without ripples. You might need to try again, and hope that the ripples aren't permanent!
    Good luck to you... I hope it works out.
    Shaun Maxwell
    Clan Maxwell Society
