Results 1 to 10 of 11
    7th September 14
    Edmonton
    Flashes .. Single/Double ?
    With knitted/loomed, after they are tied one is left with two ends to arrange nicely to show under the hose turn down. The flashes made on elastic or other have two sets to hang under the hose turn down. I've begun sewing up my own 'ribbons on elastic' to build up the collection. The other day I made a grey set with only a single and thought it looked rather good. Should the hose flashes be double?
    18th August 13
    Quote Originally Posted by Taskr View Post
    My opinion (from a traditional point of view) is, if flashes are meant to simulate the two loose ends of a hose tie, then yes, there should be two. Obviously, you may do what you will.
    Allen Sinclair, FSAScot
    Eastern Region Vice President
    North Carolina Commissioner
  3. The Following 5 Users say 'Aye' to ASinclair For This Useful Post:
    FWIW, I prefer to flip flashes back up and over so only a small portion is showing. I think the longer length showing is rather dorky, but that's IMHO.
  5. The Following 5 Users say 'Aye' to Mael Coluim For This Useful Post:
  6. #4
    22nd December 10
    Virginia
    I don't use flashes with the elastic band, but nevertheless, I arrange the ties such that very little are exposed. I like them to keep my hose up. Beyond that, just a splash of colour is nice. But not too much.
    That being the case, a single bit exposed would probably go largely unnoticed. I don't think it matters either way. If you like the look, then I say go for it.
  7. The Following User Says 'Aye' to Spartan Tartan For This Useful Post:
  8. #5
    Yes since flashes are the vestige of a bow, one would see two ends, and perhaps also two loops.
    Here in 1852 flashes had got quite huge and showy in the army
    With the new uniform introduced in 1855 the flashes got dialed back considerably, and were worn under the turnover cuffs, not over the cuff as previously (the Pipe Major looks like he's having a bad day)
    Modern military flashes are doubled, either with loops or without, but these Seaforth Highlanders ones appear to be single
    For sure the pipers of The Queens Own Highlanders, then The Highlanders, wore interesting wide single flashes made from thick striped material that reminds me of Guatemalan work
    Here are the military single flashes, on the left the Queens Own Highlanders pipers', on the right the Scots Guards pipers'
  9. The Following 3 Users say 'Aye' to OC Richard For This Useful Post:
  10. #6
    9th July 15
    Banks of the Black Warrior River USA
    Ah nice, the big ones look great with the spats.
  11. #7
    11th March 06
    Near Birmingham U.K.
    What an array of tartans due to amalgamation! Cameron of Erracht kilts and plaids (Queen's Own Cameron Highlanders), Gordon pipe bags (Gordon Highlanders) and Mackenzie ribbons (Seaforth Highlanders ).
    The Kilt is my delight !
  12. #8
    Nice to see that the hose tops are not worn too near the bottom of the knee in OCR's pictures . Hose worn too high is something that seems all too common these days and looks dreadful.
  13. The Following 2 Users say 'Aye' to Jock Scot For This Useful Post:
  14. #9
    Quote Originally Posted by freddie View Post
    It was sad, in a way, for the creation of The Highlanders to finally put the kibosh on the Prince Charles Edward Stuart tartan of the old 72nd Highlanders.
    The pipers of the Seaforth Highlanders, and then the pipers of the Queens Own Highlanders, wore a rear ribbon of that tartan for nearly a century (1881-1994).
  15. #10
    11th March 06
    [QUOTE=OC Richard;1309740]It was sad, in a way, for the creation of The Highlanders to finally put the kibosh on the Prince Charles Edward Stuart tartan of the old 72nd Highlanders.
    I love the Prince Charles Edward Stuart tartan (not as bright as classic Royal Stewart) and I'm hoping to buy a kilt in this tartan in the summer. Marton Mills do a nice version in their Jura range but worryingly it's not showing on their website anymore. The only other mill weaving it in heavyweight is Dalgliesh, but I couldn't afford that one
