Results 1 to 9 of 9
    20th August 15
    London
    Kilt and Trews Jacket for Reeling/balls
    Morning all,
    I'm new here but have enjoyed visiting the forum for a while as a guest. I've got a tailoring question now though so I thought I would sign up to ask your advice.
    I'm looking to get a jacket or doublet tailored with a few specific requirements. I'd like a jacket (probably in a muted velvet colour) with a cut that is free enough that it can be worn reeling but also smart enough that it can be worn to white tie events like the royal caledonian ball. Finally, and I'm not sure if this is possible, I'd like to be able to be worn either with trews (which I own) or a kilt (which I will get made).
    I have done a lot of trawling round the web and seen many things that are close (balmoral/rothesay doublet or regulation) but none quite hit the mark. If anyone here knows of any photos or tailors in the UK that I should ask I'd be grateful.
    Finally would appreciate your thoughts on jackets/doublets that button all the way up to the neck (hiding the bow tie and shirt) or, like the balmoral, ones that show the bow tie; both in terms of comfort and smartness.
    Many thanks in advance for the advice!
    Scot-ish
    15th March 12
    Scot ish, you seem to be making a lot of demands on a single jacket. The simplest answer, of course, for formal kilt or trews is the prince charlie. It can be as formal as you need, including the Royal Caledonian Ball.
    If you look good in trews (those of us with girth absolutely don't), then you will look good in whatever you choose, including doublets. With this choice, you definitely want to consider lace if you want a really formal look.
    For most of us, a PC and a tweed Argyll will get us pretty much any where we want or need to go. Good luck with your search.
    St. Andrew's Society of Toronto
  3. The Following 2 Users say 'Aye' to JohntheBiker For This Useful Post:
    One needs to be honest with oneself even with properly cut trews. If you are even slightly broad about the beam you need to be careful, otherwise the dreaded "eggcup" look-------think large egg in small eggcup-----will occur. Bespoke tailoring, not made to measure, may help but even the best tailor can only do so much to flatter ones figure. A PC does look very smart with trews, as is does resemble some styles of the British Army mess jacket a wee bit. Out of interest, for more casual events a well fitting pullover worn with trews, can look very smart too.
  5. The Following 6 Users say 'Aye' to Jock Scot For This Useful Post:
  6. #4
    5th July 11
    Inverlorne
    4 Post(s)
    I quite like my Balmoral doublet and I think one could certainly reel in it. I've worn it to the Toronto St. Andrews ball and danced all night. I like that I have the option to wear a bow tie or a jabot and feel the open collar gives the jacket a civilian look. Certainly, the Charlie or Kenmore would fit the bill as well. It's really your call. If it fits correctly, the doublet should handle kilt, trews and dancing just fine. If it's velvet, expect to perspire more whilst dancing in a heated ballroom.
  7. #5
    5th June 14
    Livonia, MI
    I'm inclined to think that a high enough rise (at least to the "equator") and a properly cut taper (meaning one which is straight with clean drape as opposed to one which follows the contour of the rump) could negate the "eggcup" look... I've noticed that this very combination of high rise and good drape does wonders to reduce the visual impression of my own weight whilst in trousers. That said, if memory serves, there is no drape to trews, which are typically cut unbelievably slim. The creation described above would therefore be trousers with some distinct Scottish inspiration.
    As another thought, a doublet or jacket which covers the waist of the trousers plus even a wee bit below can also create the illusion of a more impressive figure. Something like a Balmoral in a cloth comfortable for reeling may be a good solution. One could simply wear the front open with a vest for reeling, or closed with no vest otherwise.
  8. #6
    20th August 15
    London
    Many thanks all for the sage advice. I am lucky enough to be young and relatively trim at the moment so I'm not so worried about the egg cup look. the trews aren't hugely slim anyway but are cut to british military standards and height so coupling a jacket and kilt belt would probably see me through.
    I'm really torn between a wool jacket in regulation or charlie style and something a bit more unique in velvet. If I'm only going to have one made it might as well look special... on the flip side if I'll be dancing in it a lot I'm aware velvet might cook me a little quicker. Then again, you warm up very fast in a prince charlie if its a big ball anyway.
    I was thinking of maybe getting a balmoral with buttons that could be removed for thin gold/silver chain or braid as I've seen done elsewhere to hold the two sides of the jacket together for a bit more freedom dancing. Danger of upsetting the traditionalists?
    All experiences and advice so far and yet to be given hugely appreciated.
    Scot ish
  9. #7
    13th January 14
    Wisconsin, US
    I am a big fan of my regulation doublet. It is a sharp look that goes well with trews and kilt. It is also a bit more comfortable and forgiving for a full belly after dinner or while dancing. My only concern is that a doublet like this is really only good with a more formal look and I would not use it for daywear or casual settings.
    Here is my doublet shortly after I got it this last year (pardon the size of the bowtie, I have gotten better at fitting and tying it since)...
    Vestis virum reddit
  10. The Following 5 Users say 'Aye' to IsaacW For This Useful Post:
