Results 1 to 5 of 5
    15th January 15
    Norman, OK
    Short sporran chains/belt
    Good Morning,
    Does anyone have a recommendation for a shorter sporran chain or other option that doesn't involve a belt and hangers? A sporran hanging halfway down the kilt is a wee bit low.
    Aut Viam Inveniam Aut Faciam
    Proud Member of Clan Macpherson!
    "Touch not the cat bot a glove"
    7th February 11
    London, Canada
    With it being a chain, can you not remove some links and re-connect?
    Perhaps a photo would help us to respond - plus a real closeup of the chain.
  3. The Following User Says 'Aye' to Father Bill For This Useful Post:
    26th February 12
    Lake in the Hills, IL
    38 Post(s)
    I removed the D-ring strap from my sporran and then picked up a narrow women's belt of appropriate length, slip it through the sporran and buckle in back, looks great and being a goodwill purchase was dirt cheap
    "Everything is within walking distance if you've got the time"
  5. The Following 2 Users say 'Aye' to GrainReaper For This Useful Post:
  6. #4
    15th January 15
    Norman, OK
    Thanks guys! I hadn't thought of cutting out links in the chain. The small belt idea is also good.
  7. #5
    7th February 11
    London, Canada
    To be quite honest, having used both a chain and a strap, I'll never wear a chain again - the strap is so much more convenient!
    If you choose to use one, make sure that the dye isn't a sort that will transfer to your kilt, and that the edges are well and firmly rounded to prevent chafing.
