Results 1 to 10 of 13
    11th July 12
    Anchorage, Alaska
    Another Tartan on the Loom
    I finally started weaving another tartan...hopefully to become the kilt I wear with my SAMS uniform.
    Kilt fabric isn't the easiest to weave, but I rather enjoy it.
    "Once you can accept the universe as matter expanding into nothing that is something, wearing stripes with plaid comes easy." - Albert Einstein
  2. The Following 12 Users say 'Aye' to Truitt For This Useful Post:
    5th August 14
    Oxford, Mississippi
    That is going to make a fine kilt for your SAM uniform. I do enjoy your projects.
    22nd January 07
    Morganton, North Carolina
    This looks like the Kilgore tartan, except white for yellow.
  5. #4
    26th February 12
    Lake in the Hills, IL
    38 Post(s)
    I wish I had your abilities, and a loom would be helpful too!
    To stitch up a kilt from tartan you wove yourself has to be amazing.....
    "Everything is within walking distance if you've got the time"
  6. #5
    I'm looking forward to seeing this.
  7. #6
    7th February 11
    London, Canada
    You do absolutely beautiful work, and the photography isn't bad either!
  8. #7
    24th September 04
    Truitt, Can you please take a pic of your sectional beam and the lees sticks tied to the back top roller.
    Forum Owner
  9. #8
    16th January 16
    Bow, New Hampshire USA
    While i have no idea how this thing works, the woodworker in me thinks it would be a blast to build. Amazing project by the way.
  10. The Following User Says 'Aye' to kiltedcontractor For This Useful Post:
  11. #9
    11th July 12
    Anchorage, Alaska
    I'm not sure my loom was designed for the rigors of weaving kilt-weight tartan. I sheared this high-test (grade 5) bolt. This is the anchor for the tension brake, so it takes the full impact of every beat. I guess I will have to drill the plate and install a bolt of larger diameter
  12. #10
    Or a shorter bolt. The bolt you have snapped at the bolts weakest point. There was so much force on the long shank it gave quite a bit of lateral pull.
    Bobbie's loom has a shorter bolt. The eye of the tension cable is secured quite close to the metal side plate. There is almost no sidewards angle or tension on the bolt shank.
