Results 1 to 5 of 5
    9th September 16
    Annapolis, Maryland (MD)
    How do you put on a kilt pin?
    I know this sounds like a stupid question but, how do you put on a kilt pin?
    Does it go through only the top apron or do you pin it through both top and bottom to hold them together so they don't open up?
    Also, is there a specific place you are supposed to put it? High, low, middle?
    I have seen some clan badges that look like they would make a nice "pin" instead of an actual kilt pin.
    Larry
    You never, ever pin the two aprons together. You will tear your kilt.
    There are some who will tell you that the pin is to hold the apron down in the wind. Sorry. I have another apron right behind the first. If the outer apron blows up I still do not have a modesty problem.
    The kilt pin is bling. The equivalent of a lady putting on a brooch. That little glint of jewelry in your outfit. Most kilt guys use something meaningful to them. A clan crest, a badge of a club or organization something just pretty.
    The pin can go anywhere on the right side of the apron. You can put it down low or up high. It is your kilt and your pin. Where you put it is all up to you.
    Personally my pins are ALWAYS, EXACTLY 2.864" in from the right edge and 3.42" up from the bottom. If you believe this I have a wonderful bridge I can sell you really cheap.
  3. The Following 4 Users say 'Aye' to The Wizard of BC For This Useful Post:
    7th April 13
    Switzerland
    ... Personally my pins are ALWAYS, EXACTLY 2.864" in from the right edge and 3.42" up from the bottom. If you believe this I have a wonderful bridge I can sell you really cheap.
    With you being an engineer, I would believe that you have a template
    So where is that bridge? I need one to hide under.
  5. The Following User Says 'Aye' to Carlo For This Useful Post:
  6. #4
    5th August 14
    Oxford, Mississippi
    As far as the Great and Powerful Wiz measurements for kilt pins, (ignore that man behind the screen), I concur.
  7. #5
    24th September 04
    If you need a bridge to hide under the first thing you need to do is find a troll. Follow him back to his bridge and ply him with single malt till he passes out.
    Forum Owner
  8. The Following 3 Users say 'Aye' to Steve Ashton For This Useful Post:
