Results 1 to 10 of 13
    21st October 08
    sterling, ny
    Wide knife pleat vs box pleat
    I'm at the point of pressing pleats, which I'm not finding easy, I tried tacking them down but found it just made for wavy pleats. Part of the issue I'm running into is in the slight overlap in the back of the pleats from adjusting the pleats narrower then the ideal for the pattern. As I started stitching the edges to make everything easier to press to as perfect a line I couldn't help thinking it looked good albeit different as a knife pleat. In the pic the pleats with the white thread holding the edges are knife style and lay flat while the box pleats on the left have been pressed flat. It won't take much for me to finish stitching down the other side to make box pleats but I can't decide if its worth the effort to do so and just not stick to wide knife pleats; thoughts?
    7th September 14
    Edmonton
    On uploading pictures, if the file is too large it won't play. I email them to myself and select "small" when prompted for attachment size.
    21st October 08
    sterling, ny
    Quote Originally Posted by Taskr View Post
    That did it, thanks
    7th September 14
    Edmonton
    Given the width, box pleat gets my vote for visual appeal draped, and appears it flashes the yellow stripe more prominently. Looks good
    and, you're welcome
    I'm not sure I understand the problem. Perhaps you could re-word your description a little better.
    Oh, and when you baste be very carefull to keep the pleats below the bottom of the Fell perfectly straight and parallel. The way this kilt is basted will cause large, shower curtain folds in the back of the kilt.
    7th September 14
    Edmonton
    I think it just comes down to; is box pleats or wide knife pleats better. If that's a standard weave tartan, the pleats are about 2"wide which support box well.
    21st October 08
    sterling, ny
    Basically I tried basting like the book said and that failed, the 4 pleats on the right side are the result and not as straight as I'd like, so I started stitching the edges to get them straight for pressing. But in doing so I thought it looked kind of nice as a knife pleat, the original goal was/is a box. I think the problem with basting and pressing was the fact that the back of the box pleats overlap so it isn't flat under the pleats and I'm not that skilled with an iron. Just trying to decide if it will ultimately look odd with just 12 wide knife pleats and seeking some collective wisdom.
    So, can I ask why you chose to make narrower box pleats? If you look at a perfect box pleat the reveal will be 1/3 of a full Sett. It is not uncommon for box pleats to be 2.5 to 3 inches wide.
    This would eliminate any excess overlap except behind the Fell where the pleats are tapered.
    An example of extreme box pleat overlap is a Military box pleated kilt.
    A box pleated kilt is called a 4 yard kilt as it will usually take about half the amount of fabric as a narrow knife pleated kilt.
    The wide knife pleats are done for two basic reasons. One is to create a more rugged looking kilt. Sort of like a cargo kilt. The other reason is to save fabric. The wider the pleat - the fewer pleats - the less fabric. This is the way the low yardage or 5 yard kilts are made.
    Oh, and by the way - We don't iron a kilt. We press. We use the heat from steam to soften the fibers and then press down - HARD.
    We do not move the iron over the fabric. We press - lift - press. The basting is just to hold everything in place while we press. You will usually pull slightly, just enough to take the slack out of the fabric, the pleats to get the fabric to lay flat between the rows of basting.
    21st October 08
    sterling, ny
    Going exactly 1/3 of the set wouldn't have been optimum for my measurement, I first went wider but the small gap created seemed like it wouldn't let the pleats move as well while going slightly narrower would.
