Results 1 to 10 of 18
    7th May 09
    Jacksonville, FL
    A Question for Weavers. About Weaving!
    So, I'm trying to gain some insight into the economics of weaving in the pre-industrial age. It seems to me that at approximately 50 threads to an inch and 27 inches wide, warping a loom would be an extremely time consuming task.
    How much time would an experienced weaver typically spend warping a loom for a run of tartan cloth?
    How much time to weave one yard when the actual weaving began?
    Thanks!
    2nd January 10
    Lethendy, Perthshire
    17 Post(s)
    I warp 1140 ends, it takes me a day to calculate, warp and dress the loom. Depending on the complexity of the pattern, I can weave 4-8 yards a day using a single-box flying shuttle loom.
  3. The Following 7 Users say 'Aye' to figheadair For This Useful Post:
    7th May 09
    Jacksonville, FL
    Thank you! That's very helpful to me.
  5. #4
    2nd January 10
    17 Post(s)
    I should have added that a 3 day turn around for a kilt length is therefore not unreasonable for a fast weaver using a flying shuttle loom. That's a couple of hours work at most for a modern power loom which is why one can't buy hand-woven cloth in the shops nowadays.
  6. The Following 2 Users say 'Aye' to figheadair For This Useful Post:
  7. #5
    7th May 09
    Jacksonville, FL
    I always find it instructive to put things into economic terms.
    By your example, assuming a labor rate of $30 per hour, the labor alone would be valued at $720. Add in the cost of material, (and I admit I have no idea what wool thread costs) and I'd not be surprised to see the cost exceed $1000. If there is a retailer involved, the price would increase again.
    Now my point is that, while the figures involved may have been smaller, the value, in absolute terms, of that fabric in pre-industrial times would have been comparable. A length of tartan fabric is now and always has been a significant investment. Is it any wonder then that plaids were so often repaired and repurposed.
  8. #6
    6th February 17
    Lucerne, Switzerland
    I think (but don't know) you would have to correct your assumption to something more on the lines of 13-20$ per hour.
  9. #7
    7th May 09
    Jacksonville, FL
    Pick any reasonable figure for skilled labor that you like. Personally, I think $30/hour is a little conservative for skilled specialist labor with unique tools.
    The point I'm making is that a kilt length of fabric is worth the equivalent of 3 days work by a skilled and experienced weaver. That economic value is not, and never has been, trivial.
