Results 1 to 4 of 4
    10th January 19
    Houston, Texas
    Question about pleating on casual kilts
    Rocky,
    I noticed from your photos that some of the casual kilts are pleated to the sett (i.e. Sterling, Tara, and St. Andrews) while others are pleated to the stripe (i.e. American Heritage, Glyndwr, and Scottish National).
    I expect to order another casual kilt within the next 6 weeks, and I'm trying to decide what to order.
    There are certain tartans that I like (or prefer) pleated to the stripe, while there are others that I only like pleated to the sett. And for the ones pleated to the stripe, I have distinct preferences about which stripe I like best.
    The current top four contenders:
    Holyrood: Is this normally pleated to the sett (or ever pleated to the sett)? If not, do you have a photo of what the pleats look like?
    St. Andrews: Is this normally pleated to the sett? (Obviously, based on the photos, it's an option.) If it's not normally pleated to the sett, what is the best way to request that on my order?
    American Heritage: This appears to normally be pleated to the white stripe. Is that correct?
    Oakleigh: The one example appeared to be pleated to the stripe, but not the yellow stripe. What would be the best way to request the pleat be to a particular stripe?
    Thanks
    8th February 04
    We pleat our Casual kilts is based on the size of the sett and the amount of cloth used. The only kilts we typically offer a choice of pleating on is our 8 Yard Wool kilts.
    That being said, for the tartans you have listed, in our Casual kilt, here's how we would pleat them (and unfortunately, we don't have images of completed kilts):
    Oakleigh - Stripe (typically, the double yellow stripes, though if you wanted a different stripe, we could do that)
    American Heritage - Stripe (typically, the white stripe, though if you wanted a different stripe, we could do that)
    St. Andrews - Sett
    Holyrood - Stripe (typically, the white stripe in the brown, though if you wanted a different stripe, we could do that)
  3. The Following User Says 'Aye' to RockyR For This Useful Post:
    Times Change....I've owned six USA Kilts Casuals pleated to the stripe.
    Douglas
    Gordon Modern
    Ramsay
    Warrior
    McPherson Hunting
    Scott Green Weathered
    If I recall correctly (factor in olde age) the pleat pattern was chosen at the factory...
  5. #4
    10th January 19
    Houston, Texas
    Thanks for the pics
    Thanks Riverkilt. That was more helpful than you might have expected. Ramsay and Oakleigh are nearly identical (there's a color difference), and Warrior was actually 5th on my list (even though I only asked about the top 4).
    Generally, yes. But I always like to ask. In part, it helps me know what I'm buying. I prefer some tartans to the sett. I prefer others to the stripe. In this case, it helped me choose which tartan I was buying. (I chose St. Andrews over Holyrood. I'll probably eventually get American Heritage as well, but that may be a few years down the road.)
