Results 1 to 2 of 2
    imbrius's Avatar
    imbrius is offline Oops, it seems this member needs to update their email address
    6th August 18
    Milwaukee, Wisconsin, USA
    Pleats driving me insane
    I had the kilt pressed. Everything was lined up. It was beautiful. You truly couldn't see the pleats - the tartan pattern was the same front and back. Then I wore it all day at work yesterday and out to dinner in the evening. By the time I was done with dinner, the pleats were so folded over, creased, and generally jacked up that it looked terrible.
    I do sweep them when I sit and I doubt it's my sitting at work that's the culprit; I think it's getting into the car and sitting on the bench seating in the restaurant: both places you have to slide in sideways, that's causing the problems.
    This time I didn't steam it, or do anything. I simply hung it up like normal, hoping that gravity will pull the creases out.
    What am I doing wrong? Or does this happen to everyone? BTW, 5 yard wool kilt.
    28th May 13
    Calgary, Alberta, Canada
    This is much more of a problem with 5 yd kilts.... I keep a scarf in my car and will use it to keep the pleats in place as I get into a car ...not really practical for other situations. As I’m sure has been suggested get a portable steamer and use it when you get home and accept that some wrinkles are inevitable with a 5 yd kilt
    A. A. Milne
  3. The Following 2 Users say 'Aye' to Liam For This Useful Post:
