Results 1 to 10 of 11
    28th November 20
    UK
    Kilt height guide. Sort of.
    Could have gone into any of a number of sub forums, but it wouldn't be safe for work wherever I put it so here it is Warning - sweary!
    https://www.youtube.com/watch?v=AJ_fFLaljY0
    "Humanity is an aspiration, not a fact of everyday life."
  2. The Following 6 Users say 'Aye' to Micrographia For This Useful Post:
    Well. He does have a point!
  4. The Following 4 Users say 'Aye' to Jock Scot For This Useful Post:
  5. #3
    11th November 21
    Edinburgh, Scotland
    Very good
    Now are we going to have to debate if half-way up the knee is actually the correct length…
  6. #4
    24th September 04
    My stand on the bottom edge of a kilt debate. -
    I was taught that the correct height of the bottom of a kilt was just at the top of the knee cap.
    This was arrived at, using an old kiltmaker trick.
    When making a "Traditional Style" kilt the kiltmaker would have the customer kneel on the floor. The kiltmaker would then feel for the bottom of the customers ribcage at the side. They would then measure the length from the bottom of the ribs down to the floor.
    This would then be made into a kilt with this length from the bottom of the ribs to the floor as the total length of the kilt.
    But when making the kilt in the Traditional manner, the top straps are installed 2" below the top band of the kilt. From the center of the top straps to the top of the kilt the pleat shaping would taper outward to go over the bottom of the ribs. This area of the kilt is known as "The Rise".
    The size of a kilt made in the traditional manner would be listed being as long as the "Drop". But the total length of the kilt from top band to selvedge would be "Drop + Rise".
    When the customer put the kilt on they would chinch the top straps into the smallest part of the human body. This is the anatomical waist which happens to be just under the ribs at the side.
    This would raise the bottom, or selvedge edge, up by the same 2 inches.
    A human adult male patella or knee cap is just about 2". So the bottom, selvedge edge, of the kilt would end up right at the top of the knee cap.
    Not understanding the old kiltmaker trick (OKT) many guys mistook where the bottom of the kilt should be when worn, thinking that if the kiltmaker measured down to the floor, then the kilt should just brush the floor when worn. This is a very often heard myth.
    Forum Owner
  7. The Following 3 Users say 'Aye' to Steve Ashton For This Useful Post:
  8. #5
    Quote Originally Posted by Regimental View Post
    Very good
    Now are we going to have to debate if half-way up the knee is the correct length.
    For sure people can debate about their opinions on what is "correct" but when I put my historian cap on I just look at the evidence, which shows:
    1) Kilt length has been fairly stable over the centuries, certainly showing less variance than most other aspects of clothing. The maximum variation amongst experienced kilt-wearers is only around 2 inches over the last couple hundred years.
    2) Kilt length, within the same time period, has always varied a bit from individual to individual.
    3) In the 18th century it tended to be around the top of the knee, while throughout the Victorian period and the 20th century it varied between the top of the knee and the middle of the knee, the kilt covering around 1/3 of the knee being average.
    4) The army continued the slightly higher stance for a longer period that civilians tended to do.
    5) There is a recent trend to keep the kilt a bit lower, with the kilt covering around 2/3 of the knee or even all of the knee. Seems to me that this trend is mainly powered by newer, inexperienced kilt-wearers, and Pipe Band drummers. (Why so many Drum Corps have low kilts while the Pipe Corps have proper kilts I have no idea.)
  9. #6
    11th November 21
    Edinburgh, Scotland
    Some of the lower kilt wearing is definitely driven by inexperienced kilt wearers not quite realising what it should look like.
    But I think some of it, in my experience, is also driven more consciously by younger people wearing it in a more casual context, where wearing it at the correct height can feel/look a bit odd a bit odd around the waist (at least to people used to low waisted jeans etc) They therefore wear it lower around the waist, leading to it consequently sitting too low at the knees. This is so common, at least in Scotland, that it’s almost become a look in itself! Arguably, just as civilian kilts are shorter than military kilts due to the way they are worn, there is perhaps a case for kilts targetted at the casual / rugby / football crowds to be cut a little shorter still, to remove the issue.
  10. #7
    Here's a modern Grade One pipe corps, most pipers have some knee showing, though one fellow's kilt is drooping in the back.
    How does a kilt stay up in front and droop in back like that??
    But oh dear me the drummers!!
    The goal is to have no leg showing, and to have an expanse of shirt visible between waistcoat & kilt.
  11. The Following User Says 'Aye' to OC Richard For This Useful Post:
