4th November 04, 10:57 AM
What Fabric Are You Seeing?
For those about to shop for new material for a kilt, or for those who REALLY want to know what their kilt is made out of... here's the test to determine you material.
To identify fabric that is unknown, a simple burn test can be done to determine if the fabric is a natural fiber, man made fiber, or a blend of natural and man made fibers. The burn test is used by many fabric stores and designers and takes practice to determine the exact fiber content. However, an inexperienced person can still determine the difference between many fibers to "narrow" the choices down to natural or man made fibers. This elimination process will give information necessary to decide the care of the fabric.
WARNING: All fibers will burn! Asbestos treated fibers are, for the most part fire proof. The burning test should be done with caution. Use a small piece of fabric only. Hold the fabric with tweezers, not your fingers. Burn over a metal dish with soda in the bottom or even water in the bottom of the dish. Some fabrics will ignite and melt. The result is burning drips which can adhere to fabric or skin and cause a serious burn.
Cotton is a plant fiber. When ignited it burns with a steady flame and smells like burning leaves. The ash left is easily crumbled. Small samples of burning cotton can be blown out as you would a candle.
Linen is also a plant fiber but different from cotton in that the individual plant fibers which make up the yarn are long where cotton fibers are short. Linen takes longer to ignite. The fabric closest to the ash is very brittle. Linen is easily extinguished by blowing on it as you would a candle.
Silk is a protein fiber and usually burns readily, not necessarily with a steady flame, and smells like burning hair. The ash is easily crumbled. Silk samples are not as easily extinguished as cotton or linen.
Wool is also a protein fiber but is harder to ignite than silk as the individual "hair" fibers are shorter than silk and the weave of the fabrics is generally looser than with silk. The flame is steady but more difficult to keep burning. The smell of burning wool is like burning hair.
Man Made Fibers
Acetate is made from cellulose (wood fibers), technically cellulose acetate. Acetate burns readily with a flickering flame that cannot be easily extinguished. The burning cellulose drips and leaves a hard ash. The smell is similar to burning wood chips.
Acrylic technically acrylonitrile is made from natural gas and petroleum. Acrylics burn readily due to the fiber content and the lofty, air filled pockets. A match or cigarette dropped on an acrylic blanket can ignite the fabric which will burn rapidly unless extinguished. The ash is hard. The smell is acrid or harsh.
Nylon is a polyamide made from petroleum. Nylon melts and then burns rapidly if the flame remains on the melted fiber. If you can keep the flame on the melting nylon, it smells like burning plastic.
Polyester is a polymer produced from coal, air, water, and petroleum products. Polyester melts and burns at the same time, the melting, burning ash can bond quickly to any surface it drips on including skin. The smoke from polyester is black with a sweetish smell. The extinguished ash is hard.
Rayon is a regenerated cellulose fiber which is almost pure cellulose. Rayon burns rapidly and leaves only a slight ash. The burning smell is close to burning leaves.
That's your lesson for today. You may now go and watch your cartoons until you're called for dinner.
Arise. Kill. Eat.
5th November 04, 05:02 PM
OH MY !!!! FIRE !!!! MY HOUSE IS ON FIRE!!!!! WHOSE IDEA WAS IT TO SET MY KILT ON FIRE !!!! GOTTA GO THE FIRE TRUCKS ARE PULLING UP.
JUST KIDDING
CHRIS
JIMMY AS ALWAYS YOU ARE A FOUNTAIN OF COOL INFO!
Man Made Fibers
Arise. Kill. Eat.
JUST KIDDING
CHRIS
Man Made Fibers
Arise. Kill. Eat.
JUST KIDDING
CHRIS
