Results 1 to 7 of 7
    21st March 19
    Ottawa, Ontario, Canada
    Campbell of Breadalbane
    Hi Serial Kilters,
    As I was looking through the tartan registry like I always do, I found the Campbell of Breadalbane tartan. Is it possible to pleat a a kilt to both yellow strips? Would the green ground be too wide to allow that? Would you have no choice but to pleated to one strip? Curious to find out!
    Thx!
    Clan Logan Representative of Ontario
    https://www.instagram.com/clanlogan_ontario_canada/ (that's where i post my blogs)
    https://www.youtube.com/channel/UCVgTGPvWpU7cAv4KJ4cWRpQ
    2nd January 10
    Lethendy, Perthshire
    17 Post(s)
    Quote Originally Posted by Patty Logan View Post
    Hi Serial Kilters,
    Thx!
    This is the original Breadalbane tartan, kne that designed for/worn by the Breadalbane Fencibles. The only way to incorporate both yellow stripes would be to use smallish setting and a wide box pleat. And by box-pleat, I mean the early 19th century style, not a modern military box-pleat. Otherwise, pleating to one of the yellow (the same one on each pleat) could work, depending on the sett size.
  3. The Following User Says 'Aye' to figheadair For This Useful Post:
    21st March 19
    …Otherwise, pleating to one of the yellow (the same one on each pleat) could work, depending on the sett size.
    Would that make it look like Gordon from the back?
  5. #4
    2nd January 10
    17 Post(s)
    In broad terms, yes.
  6. The Following User Says 'Aye' to figheadair For This Useful Post:
  7. #5
    Yes with Gordon the yellow line is flanked with green on both sides, whereas with that Breadalbane you'll have the yellow line flanked with green on one side and black on the other.
    In "modern colours" where the green is quite dark it won't make much difference.
    I'd try pleating it to the pairs of black lines on the blue block, just to see if that's better than the yellow.
    But if that were a modern military tartan they'd almost certainly choose the yellow- they go with the light stripe if there is one.
  8. #6
    21st March 19
    …whereas with Breadalbane you'll have the yellow line flanked with green on one side and black on the other.
    Black and green for the yellow lines…interesting.🤔🤔🤔
    As for the the “train track” line on blue, I had a similar idea when it came to the black watch tartan but was told by several people (including Peter) that the pleats would have to be very very deep since the they don’t repeat every time just every 2nd time on blue if you know what I mean? And thoughts would be more expensive since it will require twice as much fabric.
