Results 1 to 10 of 10
    1st August 10
    uk
    Elementary help for a ‘handless’ incompetent
    On one of my kilts, according to my estimation worn around 500 times and still in excellent condition, the strap on the left hip, securing the inner apron to the outer via the buckle, is wearing thin and coming somewhat loose. By all accounts, this seems a relatively trivial matter but my manual capabilities are extremely limited, extending scarcely beyond flipping a light switch, so to me this poses an acute problem.
    Is there a simple way such a strap can be repaired or replaced?
    Since the strap is rooted within the sown area of the under apron, it would apparently require opening that section, removing the ageing strap and inserting a new one, followed by securing the sown area.
    If this requires more or less professional attention I would be grateful to know of such persons or agents who live in the greater Philadelphia /northern Delaware area, to where we have moved only recently.
    8th September 24
    Kansas City, MO, USA
    Any decent tailor should be able to help. I know it's not close, but USAKilts should also be able to help replace the aging strap.
  3. The Following User Says 'Aye' to spr0k3t For This Useful Post:
    1st August 10
    uk
    Many thanks for this reassuring post.
  5. #4
    2nd January 10
    Lethendy, Perthshire
    17 Post(s)
    Any UK based kilt maker could do this for you.
  6. The Following 2 Users say 'Aye' to figheadair For This Useful Post:
  7. #5
    1st August 10
    uk
    Yes, thanks for replying. However, we have only recently moved to the US. I did contact US Kilts on another unrelated matter and they replied to say they only deal with kilts they have produced themselves.
  8. #6
    21st June 22
    Waukesha, WI
    Hi, KS. I sent you a private message with information that I hope will prove helpful for you.
  9. #7
    4th January 23
    Connecticut, USA
    When I needed some work done on a kilt, I was directed to someone who makes the alterations for all the pipe/drum groups in the area. You might look for local pipers and inquire where they get their alterations and repairs done.
  10. #8
    16th March 20
    Owego, NY
    Bob F has a good suggestion. Also, J Higgins will do kilt alterations, both just moving straps and complete makeovers. They are described on their website. I did call about it but ultimately decided to get a new kilt.
    "There is no merit in being wet and/or cold and sartorial elegance take second place to common sense." Jock Scot
  11. #9
    It should be possible to either replace the strap or remove, add a strengthening layer of thin leather or a sturdy tape and then replace it.
    I've done similar repairs on bags, musical instruments and garments over the years. I usually use a PVA glue which is water resistant but water soluble if soaked, so that the repair can be removed and redone if necessary.
    Anne the Pleater
  12. #10
    1st August 10
    uk
    Thank you very much for these helpful suggestions!
