2nd December 07, 12:25 PM
 Originally Posted by pdcorlis
Elegantly simple Barb! One question, does the fusible web keep the tartan from unraveling at the notch?
Some of the fusible web I've tried in the past doesn't do a very good job preventing fraying. But this new Steam-A-Seam stuff that I've just discovered really fuses well to the tartan, and you can pick at the notch with your fingernails and not get the tartan threads to pull out. I suppose it depends on how hard you are on your flashes, though. If you were worried about it, you could use a little Fray-Check on the back side.
Barb
2nd December 07, 01:14 PM
I have been wanting to try a method like what Barb describes with the scraps of MacGillivray she sent with my kilt. Though to give tartan stability and to keep it square as I would work with it (largely to match stripes), I wanted to block it square and press a layer of one-sided fusible interfacing across the entire inside surface of the tartan before I cut it down to intermediate size. Next, I'll fold the sides over the back, press flat, and then apply another strip of interfacing nearly the width of the finished flash down the back. This is the way the the flashes I purchased were constructed as far as I can tell.
I'm having difficulty finding thin, black, single-sided fusible web, though. I may look at upholstery shops next.
I made denim flashes from an old pair of jeans a few weeks ago using a thicker, two-sided fusible interfacing, being sure to press the raw edges as close to each other as possible to minimize length-wise fraying. Because the webbing was so thick, I left the top inch or so of the flash fuse-less to make it easier to stich down the loops in the second-to-last step and I did not apply a second layer of webbing on the outside.
Rex.
3rd December 07, 06:24 AM
Hi Rex
Actually, the tartan stays nice and square without having to go through the extra step of stabilizing it. And not including stabilizer makes the flashes less stiff.
BTW - Do you need me to send you more scraps of MacGillivray?
B
3rd December 07, 06:20 PM
Ah, but you have no idea how clumsy I am. Stabilizer is my security blanket!
Not yet. I think I have enough, but I'll let you know after my next attempt(s).
Thanks, Barb!
R.
4th December 07, 04:10 PM
Thanks for the tip and the great how-to pics and instructions, Barb! I'll have to try this some time (maybe over Christmas break!)!
5th December 07, 09:39 PM
I'm off to Joanne's tomorrow, to get Steam-A-Seam for X-Marks tartan flashes. The whole sewing a tube, then turning it inside out, slipping a piece of this fusible material inside and ironing it is appealing-then they would truly be reversible flashes.
Thanks Barb!
Be well,
6th December 07, 04:38 PM
Thanks Barb!
Be well,
But where will you put the seam?
I sewed some with the seams on the side:
http://www.xmarksthescot.com/forum/m...845/index.html
sorry the pics are bad, did them with my cell phone.
Wallace Catanach, Kiltmaker
6th December 07, 05:44 PM
The drawback to putting the seam on the sides is that you wind up with a ridge 4 thicknesses thick along the edges and only two thicknesses thick at the center. And the fusible web only sticks to 2 sides, so, at the seam edges, you can't really stick everything together. So it doesn't produce the really nice, flat, smooth flashes that you can get without a seam.
Anyway, there are lots of ways to make flashes! Certainly no one right way.
Hogs and quiches,
B
1st March 09, 09:27 PM
Thanks Barb I believe even I can do it.
2nd March 09, 09:06 AM
Personaly I like flashes without the notch cut out better, I leave the bottom straight, put a line of stitches across to keep them from unraveling further. Something like this:
although mine look better. ;-)
I´ll post a picture when I have one!
By RockyR in forum USA Kilts
Last Post: 4th May 07, 01:13 PM
By Josh_E in forum How to Accessorize your Kilt
Last Post: 26th May 06, 02:28 PM
By Avonlea22 in forum How to Accessorize your Kilt
Last Post: 21st October 04, 09:37 AM
