What I notice in all those photos is that, with the possible exception of the first one--the painting--all the sporrans are hanging at the right height for what's being worn, the style of the sporran, etc...I don't mean "two ox feet below the midline measurement of the wearer's third rib, excepting third tuesdays or during a lunar eclipse", rather that it's all visually balanced. Not sure of the right height? Look in a mirror. If it's under the dunlop, it's too low. If it looks like a fanny pack worn in the front, it's too high. If you think it's at a good height, go for a walk, and if it smacks you in the junk, then it's too low. Likewise, if if the strap falls off your butt, then the strap is too loose...which also happens to mean its too low.
FWIW, I've also noticed that if I'm wearing a baggy hoodie (any snowboarder has a closet full of them), I drop the sporran a little lower so it's more apparent beneath the hem of the hoodie...so...check the mirror, and mess with it until it looks "correct".
Wear it where it is comfortable. Generally, this will be a few inches (a handsbreadth, as they say) beneath the belt. The problem with wearing it too low is that it tends to slip and slide around, and it interferes with the hang of the kilt apron.
Wearing it a handsbreadth beneath your belt is great advice -- if you are wearing a belt.
If I'm wearing a waistcoat, I tend to wear my sporrans just a tad lower than otherwise, to make sure that the top of the sporran clears the bottom of the waistcoat.
If I'm not wearing either a belt or a waistcoat, I tend to wear my sporran a tad higher than otherwise, bringing it up closer to wear my belt would otherwise be. I just think it looks better given the absense of a belt.
The point is that it needs to feel secure and comfortable when you wear it. If you wear it too low, it will feel neither.
And if you have any kind of a belly on you, please make sure that your sporran is not so low that it slips beneath your belly, which not only accentuates your girth, but also makes the kilt apron hang horribly.
Yes, the book may be "strict" but when there isn't anything else available (before finding XMTS), it is a good place to start. And yes, it is meant to be a guide, not the be all to end all.
in 1950:
and today:
 Originally Posted by OC Richard
Rather than giving my opinion or inventing a rule or quoting somebody else's opinion or rule, let's just have a look-see:
So somewhere between "as a waistplate" and "as a codpiece"
Seriously though, great photos Richard!
For the OP: try wearing it around the house and while out on a good brisk walk. Where it rides on you and where it's comfortable will probably best determine where it should go. It may actually depend on your sporran and what you've got in it as well.
Regarding OC's last 2 photo's, it looks like the sporran is higher because there isn't a belt being worn. BTW, thanks for the photo's OC.
The one of MacPhedran is still lower. The usual kilt hire-style photo has all the usual kilt hire-style mistakes, to my eye.
That jacket's killer, tho...
I wonder if I could convince Josh to build me a sporran like McColl's . It looks like it would take several horses' worth of hair!
10th June 10, 09:55 AM
I really like my horse hair sporran, but could never convince myself to let the hairs hang lower than my kilt. It just seems odd to me.
11th June 10, 04:34 AM
By PneumoniaHawk in forum General Kilt Talk
Last Post: 28th March 09, 09:30 AM
By KiltedSurveyor in forum Kilt Advice
Last Post: 9th September 08, 06:21 AM
By Shardz in forum Kilt Advice
Last Post: 1st September 08, 02:24 PM
By Mike50 in forum Kilt Board Newbie
Last Post: 19th November 06, 10:01 AM
Last Post: 1st April 06, 05:24 PM
