6th December 07, 07:15 PM
#21
 Originally Posted by Barb T.
The drawback to putting the seam on the sides is that you wind up with a ridge 4 thicknesses thick along the edges and only two thicknesses thick at the center. And the fusible web only sticks to 2 sides, so, at the seam edges, you can't really stick everything together. So it doesn't produce the really nice, flat, smooth flashes that you can get without a seam.
Anyway, there are lots of ways to make flashes! Certainly no one right way.
Hogs and quiches,
B
I made a fine enough edge stitch that there were only two layers. Will have to see if the stitches come out over time...
Wallace Catanach, Kiltmaker
7th December 07, 08:49 AM
#22
So did you put two pieces on top of one another and edge stitch over the raw edges? I'm having a hard time visualizing what exactly you did to avoid a quadruple thickness at the edge seam.
B
7th December 07, 10:29 AM
#23
B
Yes, two pieces on top of each other without folding them under. With a fine edge stitch.
8th December 07, 06:53 AM
#24
I wonder if you could use a piece of Steam-a-Seam 2 in between the two layers and avoid the stitching? I'd try cutting the pieces a little oversize, steam the bejeebers out of the fusible web, and trim them to the right size. It might not ravel at all or need edge stitching. Worth a try with a small piece, anyway.
B
8th December 07, 07:06 AM
#25
Has anyone tried Dritz Fray Check?
I have used it at the bottom of cheaper flashes to keep them from fraying more or, after they started to fray, and I had trimed some off, then applied the Fray Check. After it is dry, it's a little stiff, but not completely.
It's a liquid and comes in a small bottle. I also used this product on the fringes of a Fly Plaid that I self fringed and then braided the tassels. For that application it kept the tassels from coming unbraided.
Joanne sells it here.
8th December 07, 08:12 PM
#26
Barb,
I will experiment next time I do some flashes.
Jay,
I havn't tried it.
W
11th December 07, 09:34 PM
#27
Hogs and quiches,
B
I see the point, maybe I won't do it that way. No real reason to have reversible flashes anyway. Is there any reason to put the bit of fusible web over the folded over edges in the back? If the Steam-A-Seam works on the notched edge, it should work fine here too, right?
I have used this, and posted about it, but, unfortunately, the test of time has shown that it only checks the fray for a few months
Be well,
12th December 07, 10:00 AM
#28
That's not good to hear - But I just looked at the flashes that I treated well over two years ago, and they seem to still be OK. Maybe it has to do with flexing, or usage, or washing?
Flashes, mine anyway, seldome if ever get washed. Don't get heavy usage or flexing either.
I would never think of doing the bottom hem of a kilt with this stuff, but it seems to be working with the flashes that I have treated.
Of course varnish or shellack would also work - or super glue?
12th December 07, 09:18 PM
#29
...snip...
Well, it might have something to do with being worn by a seven-year-old!
Be well,
12th December 07, 09:21 PM
#30
Be well,
Poor Panache, a 7 year olds mentality in 39 year olds body. Perhaps he'll mature some in the coming year.
By RockyR in forum USA Kilts
Last Post: 4th May 07, 01:13 PM
By Josh_E in forum How to Accessorize your Kilt
Last Post: 26th May 06, 02:28 PM
By Avonlea22 in forum How to Accessorize your Kilt
Last Post: 21st October 04, 09:37 AM
