Results 31 to 40 of 46
  1. #31
    29th January 07
    San Jose, CA
    Quote Originally Posted by ccga3359 View Post
    Poor Panache, a 7 year olds mentality in 39 year olds body. Perhaps he'll mature some in the coming year.
    Silly man. My son, not my husband. Panache is nowhere near seven years old yet!
    Be well,
  2. #32
    15th July 07
    California
    Quote Originally Posted by The F-H.C.A.G. View Post
    Be well,
    I don't remember 7. Is that before or after puberty?
  3. #33
    22nd December 06
    San Francisco, CA
    Thanks, Barb. I appreciate how you share your knowledge with all of us so graciously.
  4. #34
    2nd February 04
    Duvall, WA, USA
    Very interesting. Might have to consider doing something like that when I get bored...
    -J
  5. #35
    29th January 07
    San Jose, CA
    I finally got around to making some flashes with these instructions. Being the lazy sort, I didn't bother to come back and actually read them before doing it, of course, so I did some slightly different things, but they look great when done:
    From the back. Note the different colored backs. I had some iron-on mending tapes, so used these to finish the backs, instead of the recommended iron on tape. also, note that I did not fold the edges all the way over to meet in the middle-I figure they're covered by the iron on tape anyway.
    And from the front, after all, this is the only side that matters!
    My love says that these are the best looking flashes I have made so far. I told him, "Of course they are. They're made from Barb's instructions!"
    Be well,
  6. #36
    24th November 06
    Oregon
    Thanks, Barb, I just made some extra-swell flashes per your instructions!
    I did have a question though...I have never used fusible anything and wasn't sure of the length of time needed to properly adhere to wool--the webbing was fine but what about the hem tape? It seemed if I heated it enough to melt the glue it oozed out a little...how long/what heat do you use for that part?
    Moosedog
  7. #37
    Quote Originally Posted by Moosedog View Post
    I'm never very patient with fusible stuff, so for the hem tape, I just plop the iron on, give it a burst of steam, lean on the iron for a sec, and that's it. If I want to check to make sure that's enough, I let the flash cool and give the tape a tug. Seems to be enough.
    And, for those of you who asked earlier, I've started to use a little Fray Check on the points of the flashes - the fusible web doesn't get quite into the corners enough to prevent a few threads from coming loose. So, I just ooze a little Fray Check on the fronts and backs of the points. Once it's dry, it doesn't show.
    B
  8. #38
    24th November 06
    Oregon
    OK, thanks!
    Moosedog
  9. #39
    10th January 09
    Oconomowoc, WI
    I've been experimenting lately with a variety of materials for easily making really nice-looking flashes from tartan scraps. I wanted them to look nice both front and back, not be prone to raveling, be fast to make, and be comfortably flexible (not stiff as a piece of cardboard).
    The instructions below use what’s called fusible web, an iron-on material that is heat activated on _both_ sides (unlike fusible interfacing which is heat activated on only one side). I’ve experimented with making flashes with lots of different double-sided fusible materials. Some don’t stick very well to tartan. Some types aren’t readily available in strips that are wide enough (about 1 ½”) to make good flashes (e.g., Stitch Witchery is great, but the widest that's available is 1 1/4"). And lots of fusible materials are too heavy and make flashes that I don't like because they are too stiff.
    The best fusible material that I’ve found is called Lite Steam-A-Seam 2. It’s available at Joann Fabrics stores and at www.JoAnn.com. Lite Steam-A-Seam 2 irons well to tartan and also has the convenience of sticking temporarily before ironing. Flashes made with Lite Steam-A-Seam 2 are stiff enough to be attractive but retain a nice flexibility. And the fusible aspect keeps the tartan from raveling.
    The instructions below produce four flashes, two for each garter. I like to match the tartan in all four, or make them in two sets of mirror image pairs. But, if you have a tartan with a big sett, this actually uses up quite a bit of tartan. If you have only a few scraps of tartan (such as those left over from cutting out the pleats), you can certainly make non-matching flashes.
    For the flashes, you'll need:
    -four 3”x7” rectangles of tartan (7" is an approximate length and will make a finished flash that's about 5 3/4" long) - shorter or longer is OK)
    -four 1 7/16”x7” pieces of fusible web (see note above)
    -four 5” lengths of black iron-on hem tape
    If you need to make garters too, you'll need:
    -two 18” lengths of ¾” no-roll elastic (this will fit just about anybody)
    -two 4” lengths of ½” Velcro (gives lots of adjustment)
    Peel one side of the backing paper off a strip of the fusible web. Center it on one of the tartan rectangles; don’t peel off the other paper. Iron the paper side of the web.
    Leaving the paper on, fold the two sides of the tartan rectangle so that they meet in the center of the back of the flash. Press to set the crease. Leaving the paper in gives you a nice sharp line to fold along for pressing the edges. Open up the back of the flash, and peel off the other paper backing. Fold the sides down again, and press the flash well to fuse the web.
    Flip the flash over, and press again from the front side. Lay the piece of iron-on hem tape over the join on the back side of the flash, having the end even with the lower edge of the flash (the tape doesn’t need to go to the top of the flash because you’ll fold it over). Iron the hem tape.
    Zig-zag the top raw edge of the flash, if you want. Then fold the top edge over about 1 ¼”, and stitch close to the zig-zagged edge. If you don't have a sewing machine, you can cut another little strip of fusible web, slip it under the edge of the flash, and stick it together with the iron. Just be sure to leave enough of a channel for the garter. Cut a notch out of the bottom edge of the flash.
    If you need to make garters, too, stitch the hook and loop parts of the Velcro to opposite ends of the lengths of elastic. Make sure that you put the hooks on one side and the loops on the other.
    String two flashes on each garter, and you’re done!
    Barb
    I just looked at this thread again in preparation to make some flashes, and I don't understand what is keeping the bottom ( notched ) edge of the finished flashes from unraveling.
    I must have missed something, but judging from your photos, I don't even see a sewn or machine stitched edge to stop any fringing.
    Help please.
  10. #40
    3rd November 06
    Anchorage, Alaska, USA
    Quote Originally Posted by Bart_In_A_Kilt View Post
    Help please.
    See Barb's posts #11 and #37 in this thread. The fusible webbing runs off the bottom edge, so when you cut the fabric, the edge is supported by the fusible webbing. She also mentions using some fray check in the corners where the fusible webbing may not stop a little raveling.
    Abax
  1. EXTRA US ARMY Tartan...
    By RockyR in forum USA Kilts
    Last Post: 4th May 07, 01:13 PM
  2. style question - tartan flashes, solid flashes or no flashes?
  3. Tartan Flashes
    By Josh_E in forum How to Accessorize your Kilt
    Last Post: 26th May 06, 02:28 PM
  4. Making Kilt Flashes...anyone know how?
    By Avonlea22 in forum How to Accessorize your Kilt
    Last Post: 21st October 04, 09:37 AM
