Results 31 to 40 of 44
    3rd March 10
    43*N 88*W
    Re: Westlake Hardware stresses zombie preparedness!
    Quote Originally Posted by Deirachel View Post
    Little bit of thread zombification....but....
    It's not a water gun.
    It's a clear version of the Nerf N-Strike Recon CS-6 with the stock attached and the barrel extension not. The barrel doesn't really help with accuracy and it reduces the distance of the shot.
    For this game I would suggest a modded Longshot CS-6 using the Big Bad Bow piston spring with the original spring, or the really modded option of taking an AR-16 recoil spring and trimming it and replacing the cocking spring with a heavier spring. Makes the darts shoot up to 100 yards if done right...... attach the Raider CS-35's drum clip and your set.
    Yes, modification of Nerf guns is a hobby of mine.... we shoot at each other at work. Nerf modding can get serious (like the custom cut brass breeches for the Longshot I considered buying for $50 a pop.)
    Just by cutting to allow a full drop on the revolving cylinder and removing the air-restriction in a Maverick 6 you could get a very nice (and REALLY portable) zombie blaster.
    Shorter = better when you may have to leg-it or squeeze through a closing door/narrow gap.
    I wouldn't give the battery powered ones a second look. Their range (from what I've seen) is terrible, and who wants to risk running out of batteries when you're surrounded by braying hordes of zombies. It's TWO commodities you now need to manage vs just ammo.
    ith:
    1st August 09
    Augusta, GA, USA
    Gotta be careful with the loading when you remove the air restrictors though. Too far down on the dart and you jam.
    Argueable, With the blaster held upright, it's no wider than your body.... and if "zombies" are coming at you, you don't wait to squeeze through anything.
    ith:
    The range is dependent on the individual blaster (the Vulcan and the Stampede have decent range...), and the battery life with decent batteries are actually quite good (I've had the same set of batteries in my Vulcan for a year or so), but I do agree these are NOT the blasters to go with, just for a different reason. The batteries make the blasters overly heavy and bulky. Why add 5 pounds of batteries when you can add 5 pounds of clips and darts?
    Death before Dishonor -- Nothing before Coffee
    Nihil curo de ista tua stulta superstitione
    22nd October 04
    Wuppertal, Northrhine-Westfalia, Germany
    "Wizards in trousers? Not in my university! It`s sissy. PeopleŽd laugh." said Ridcully.
    Christian Pipe Smoker
    My Youtube Channel
    14th August 07
    Halifax, NS
    http://runforyourlives.com/info/how-it-works/
    If there was a run in Halifax, I would, by gum! train for this run.
    13th October 10
    Pennsyl-tuckey-vill-burg-town (aka central Pennsylvania, U.S.A.
    Smile Re: Westlake Hardware stresses zombie preparedness!
    Quote Originally Posted by Dixiecat View Post
    YEEEES! I HAVE to do this next year!
    30th September 10
    Chesapeake, VA USA
    We have Survive Norfolk which is like Meghans Humans vs Zombies but lasts only a night, involves a race to a finish line after hitting specific markers and no Abe statues.
    I'm a zombie this year
    13th October 10
    There should be a zombie paintball course where you have to hit them in the head (helmet/mask) to kill them before they get your life flags.
    24th September 11
    Wisconsin
    Anybody been watching The Walking Dead? Where the heck did that little girl run off to!?!? I would be so ticked off with her when I found her again. How hard is it to sit under that little stick shelter thing and wait for the sheriff to come back!!
    If I were her mom, after this little running away episode, I would be scavenging cars for one of these:
  1. Zombie Pitt Stop in Glasgow
    By Jimmy in forum Miscellaneous Forum
    Last Post: 25th August 11, 11:09 AM
  2. Denver Zombie Crawl 2010
    By Nighthawk in forum Miscellaneous Forum
    Last Post: 27th October 10, 03:29 PM
  3. Kilted to see Korn and Rob Zombie!
    By GreenDragon in forum General Kilt Talk
    Last Post: 21st April 10, 07:37 AM
  4. Would an Eskimo Give a Zombie a Brain Freeze?
    By Bygrinstow in forum Miscellaneous Forum
    Last Post: 2nd May 09, 02:22 PM
  5. a new drug to combat those pesky Zombie Bites!!
    By Kiltedfirepiper in forum Miscellaneous Forum
    Last Post: 24th July 08, 04:55 PM
