Results 1 to 10 of 12
    19th November 06
    Question need patterns for kilts!
    hello all! this is kiltman with a sword here, now that i have determined that the pattern i have is not a real kilt, i need some good patterns! if you guys have any help fpr me it would be appreciated. i would also like a couple good patterns for sporrans. and dirks. and anything else i would need. so in short i need everything you got. i really would like to have at least one kilt aoutfit done before new years. if possible i would like to celebrate in style. and maybe one of my resolutions would be to get more kilts. (and to lose some weight of course, that would be nice as well!) so please help me if you have any good ,real patterns for me.until then,
    Erin Go Bragh!
    Levi (aka KWaS)
    2nd July 06
    Madison, Wisconsin
    This is a good thread for the DIY forum.
    13th March 06
    South Mills, NC
    Regardless of which forum this thread belongs in...
    You really don't use a pattern for a kilt at all. If you boil it down to it's purest element, a kilt is nothing more than a huge stretch of fabric folded neatly to fit around your waist.
    For a first shot, I would recommend the X-Kilt: http://www.xmarksthescot.com/forum/s...ad.php?t=20085
    You could also look here: http://users.tinyonline.co.uk/chegc/kiltsite/page2.htm
    As for sporrans... ummm... I design my own, and then produce them myself.
    30th March 05
    Kentucky
    The Art of Kiltmaking - http://www.celticdragonpress.com/ - The only 'pattern' you'll need
    18th April 06
    Phoenix Metro Area, AZ, US
    Quote Originally Posted by chasem View Post
    Seconded.
    5th September 05
    Chicago
    For a first go at it, try making an X-Kilt. A mess of guys here on the forum have made them with great success. The materials are cheap, all it takes is a download, a printer, a sewingm achine and about $25 worth of materials. When you're done you have a contemporary kilt you can wear and you'll basically understand what goes into making a kilt.
    After that, if you want to try a tartan kilt, get Barb's book. I've made seven kilts, working on number eight right now (five were X-Kilts) and I'm using Barbs book...I opened it today as a mtter of fact.
    23rd January 04
    Quote Originally Posted by beloitpiper View Post
    I agree, and have moved it to the DIY'er section.
    Kilt making is a bit Zen - the pattern is there in the fabric, it is just a matter of being able to see it.
    Kilts are usually cut so that the selvage is the lower edge of the garment, which is contrary to the usual way the fabric is used.
    The exception to this is corduroy, pinstripe and anything else which should be used vertically, when it is a case of cutting strips and joining sections of pleats together.
    With a patterned fabric you usually work with the repeat of the pattern, though some interesting things happen if you don't.
    With a plain fabric I usually just make the longest length of kilting cloth possible (within reason) and work out the number and depth of pleats which will just fit into it.
    All you need to start is the fabric, a tape measure and a calculator or slide rule and the basic idea of the two fronts, the back which is a little more than half the circumference made up of pleats, plus there can be either one or two double size pleats at the edge of the aprons. Small amounts of shaping to flare the aprons might be done, depending on the style of kilt you want.
    There are some good instructions on where to put pleats and what effect to aim for on the 'net, if you do a search.
    5th November 06
    Florida
    Tapering the pleats.
    I have been reading everything I can find , both in this listing and on the internet in general. My problem is that it appears simple to effect the tapering of the pleats and like this example:
    "In our example kilt, the waist of the kilt will be narrower than the hip by 18cm. (108cm. hip - 90cm. waist). Therefore, the pleats and each side of the aprons have to be gradually tapered from the hip to the waist."
    This reminds me of the old software instructions which were written by the software writers (and could only be understood by other software writers)but impossible to be understood by anyone else.
    I understand, somewhat, how to do this with box pleats on the X-KILT but I want to use knife pleats and since I have a 6 inch difference betwen waiste and hip, how do I implement the taper? I have examined my Amerikilt, a Stillwater Economy which has no taper, and a ladies skirt kilt and still cannot work this out.
    Could someone please explain, possibly with a picture or two.
    Many thanks in advance.
    Gordon of MacHardy Clan Origin
  1. casual kilts, work kilts, and nice kilts
    Last Post: 1st June 07, 01:51 PM
  2. Bonnet knitting patterns?
    By MacWage in forum How to Accessorize your Kilt
    Last Post: 27th August 06, 11:49 AM
  3. Hand Knitted Hose Patterns
    By Southern Breeze in forum DIY Showroom
    Last Post: 24th August 06, 03:17 PM
  4. Patterns for PCs or Argylls
    By An t-Ileach in forum How to Accessorize your Kilt
    Last Post: 4th May 06, 09:46 AM
  5. Knit Kilt Hose Patterns
    By Shay in forum How to Accessorize your Kilt
    Last Post: 9th August 05, 04:39 AM
