14th September 07, 09:15 PM
Stupid question about A-shaping
When you a-shape the aprons should the angled edge run parallel with the pleats edges or should it set with the bottom running in a straight line? I've scanned the x-kilt directions but still couldn't figure it out.
14th September 07, 09:23 PM
I need some sort of a sketch or photo to visualize this question in order to answer it.
Be well,
15th September 07, 10:18 AM
here is a quick pic of my under apron end in progress. I tried to set the inner most edge square in the frame. Then ran the angled side paralell with the pleats. I went with a 2" a-shape on the outer apron, the outer edge of the inner has a 2" "flare to it too. I hope this helps.
15th September 07, 10:21 PM
No such thing as a stupid question but if I undertand you're question I think the apron should parrallel to the other pleat edges.
At least more per Alan's X-Kilt but I think most people on XMTS would support either way??
Reason: correction
17th September 07, 06:06 PM
Sorry I've taken so long to reply-distracted with my own project. I agree that the angled edge should be parallel to the pleat edges. I know that this means the bottom edge is a little angled, but this doesn't show when you are wearing it.
Be well,
17th September 07, 06:34 PM
That's how I ended up working it out as well. I can't really see another way without a great deal of extra trouble.
18th September 07, 06:17 PM
You can "tuck up" the little bit of inner pleat that shows under the bottom of the apron iffin you wanna. That's what you do with a traditional kilt, but I never bother.
19th September 07, 04:17 PM
I was wondering about the bit that hangs down. Thank you to all who helped.
By navycb in forum General Kilt Talk
Last Post: 29th September 06, 04:43 PM
By Mr. Kilt in forum General Kilt Talk
Last Post: 11th May 06, 10:59 AM
By UmAnOnion in forum Professional Kiltmakers Hints and Tips
Last Post: 1st March 06, 01:29 PM
By Mr. Kilt in forum Miscellaneous Forum
Last Post: 11th November 05, 01:42 PM
By Richland in forum General Kilt Talk
Last Post: 22nd September 05, 05:07 PM
