Results 1 to 10 of 19
    12th August 07
    Mansfield, Texas
    Proper Kilt Pin Placement
    This has probably been done to death on the boards, but I have to ask. I've worn a kilt for a while now, not everyday like you lads and lassies, but on certain special occasions. I usually wear my kilt pin on the front apron only (naturally!) and anywhere from 1/4 to 1/3 up from the bottom.
    My question is, is there a rule for the proper placement of the pin or is anywhere on the bottom half near the edge acceptable? And while we're at it, IS there a proper distance away from the frayed edge?
    18th December 06
    Burlington, Ontario, Canada
    I've heard 2" from the side, 4" from the bottom. Then again it could depend on the size and shape. Go by eye.
    24th October 04
    Cincinnati, Ohio
    This is kind of hart do explain, but ...
    I stand with my legs about shoulder width apart. The pin goes dead center over the front of my right leg (adjusted slightly if there is a dominant thread near by - less than 1/4" - to center on). Bottom of the pin right at the top of the hollow before the top of the knee.
    Adam
    I'd post a pic, but I can't find a single one that shows a pin
    15th July 07
    California
    OK - Since you asked, here is the definitive answer. All other answers are wrong!
    Bottom of kilt pin is 3 11/16" from lower edge and exactly 3" from right edge, unless the pattern of the tartan makes the pin look weird, then start adding and subtracting 3/16" from right and bottom edges until it feels right........
    Got it?
    26th November 06
    Mountain View, CA, USA
    I keep mine about and inch or so from each edge.
    I think this is a case of "to each his own."
    Just remember not to pin through both the outer and inner aprons.
    The pin should be through the outer apron only.
    And it's first function is just a weight to hold the apron down in a breeze. So lower and closer to the fringe is better than higher and further away.
    The second reason for the pin is a bit of bling or flash. So wear what looks good to you. I'm fond of my little silver kokopelli that started out as a ladies necklace.
    15th July 07
    California
    Kokopelli - now there's a term I haven't heard for a while!
    That would really go with some of the weathered tartans!
    12th August 07
    Mansfield, Texas
    Quote Originally Posted by James MacMillan View Post
    Got it?
    Is that sarcasm I detect?
    21st April 07
    Arizona
    Quote Originally Posted by Bryan View Post
    Of course not. Marines have no sense of humor I've been able to detect.
    19 Post(s)
    Quote Originally Posted by ccga3359 View Post
    Good advice there.
  1. Proper description of kilt dimensions?
    By apack in forum Professional Kiltmakers Hints and Tips
    Last Post: 12th August 07, 11:05 PM
  2. sporran placement!
    By I M Kilted! in forum How to Accessorize your Kilt
    Last Post: 15th May 06, 08:45 AM
  3. Sporran placement
    By MacConnachie in forum How to Accessorize your Kilt
    Last Post: 28th December 05, 04:32 PM
  4. Proper kilt pin placement
    By Geoduck in forum How to Accessorize your Kilt
    Last Post: 16th February 05, 02:28 PM
  5. Levis are for Liars and Proper Kilt Measurements.
    By Dreadbelly in forum General Kilt Talk
    Last Post: 6th September 04, 10:11 AM
