Page 1 of 5 123 ... LastLast
Results 1 to 10 of 43
    14th May 08
    Slovenia
    Newbie with diy question
    Hi to all!
    Where I live the kilts are seen on TV only, so I must admit I haven't try to go kilted in public, yet. Guess I'm not Man enough to to this, but I'm working on that. This is more to avoid pressure on my Family and not so much for my own reasons.
    I made my first kilt form dark blue fabric, which used to be a part of Aikido gear (plus some left-overs). The instruction from X-Kilt were used. The final product was not so bad, but the fabric wrinkles so much that I should take an iron wherever I go. So it can't be used really.
    Now I bought a sort of Camo fabric (forest) which is very light-wight. What I would like to do is light-weight summer kilt, box pleated, with sporran in same fabric (to be used as a side as a pocket or in front as a sporran). Maybe even a basballcap or hat in the same design.
    My question is; what can be done to keep the kilt from rising in the wind to much? Velcro on the hem of apron,...?
    Thanks!
    P.S.: Sorry for speling errors. English is not my native language.
    Welcome,from Inverness-shire.I am not meaning to be unhelpful, but I only know about traditional kilts made from heavy weight wool,they do not blow in the wind.I am sure you will have some very sound advice given here before long.
    11th March 08
    New Jersey
    from New Jersey!
    A kilt pin might help hold the front apron down. If you use fabric that requires a hem, the double weight at the hem might hold it down, too? Our kiltmaking experts might be more help with this than me.
    "To the make of a piper go seven years of his own learning, and seven generations before. At the end of his seven years one born to it will stand at the start of knowledge, and leaning a fond ear to the drone he may have parley with old folks of old affairs." - Neil Munro
    12th November 07
    NC
    Welcome from North Carolina!!
    9th August 06
    Fort Collins, Colorado, USA
    Welcome from Northern Colorado!
    16th August 06
    Salt Lake City, UT
    First off, welcome to Xmarks from Salt Lake City!
    As to your lifting problem, you could easily fix that permanently by sewing in a full liner to your apron. Just get some fabric remnant at the local sewing shop and sew it in. White might work, or maybe black, whatever you think will look best.
    It will add heft and body to the apron and that should do it!
    I speak from experience having used very lightweight stuff to make my first kilts.
    29th January 06
    Asheville, NC
    With light weight fabric a good option is to use knife pleats instead of box pleats. This will add mass to the rear of the kilt because you'll use more fabric. I've found that using 5 or 6 inches (12-15 cm) of fabric in each pleat provides enough mass without being too hot. I have a 38 inch (96 cm) waist, and my hiking kilts take a bit more than 5 meters of fabric, and have about 20 pleats with a 1.5 inch (4 cm) reveal at the hip and a 1.25 inch (3 cm) reveal at the waist.
    You have the X-kilt instructions, which are great for teaching you the basic "philosophy" of kilt making. If you understand how to make a box-pleat, you can easily handle a knife pleat. Also, make the apron wider (one-half your waist dimension) as if you are making a traditional kilt.
    I just laid out a camoflage hiking kilt last night, and was going to take some photos for my own records of the marking and folding process. If you'd like I will post those photos to show you how I make my pleats. There are also other threads here that discuss knife pleating.
    A sporran, properly weighted with your usual gear (wallet, keys, etc.) and a handful of coins should prevent the front aprons from flying up far enough to be embarrassing.
    TH
    Oh, and welcome to X-Marks!
    29th January 06
    Asheville, NC
    And Jim's liner idea is a good one if you don't want to always use the sporran. You only need to line the inside of the under apron, that way you don't really have to worry about what it looks like since no one will ever see it. If the over apron flies a bit, no problem. Use nice soft material since that will be against your anatomy. I've done this with cotton knit (t-shirt material) and it works well.
    Be sure to wash all the fabrics well before putting them together so that you don't have a problem of one fabric shrinking more than the other! Stitching the liner only along the top and about half way down the sides, leaving the bottom unstitched also helps with possible shrinkage issues.
    And back to your original post...never use velcro or pins to attach the aprons together. It may seem like a good option, but it doesn't work at all. The aprons need to move past one another as you move.
    20th May 07
    Madison, WI
    Welcome form Albany, New York. You should be able to find a lot of resources on this board. The amount of talent represented here is very impressive.
    Jay
    Clan Rose - Constant and True
    16th August 06
    Denver, Colorado
    Your english is fine. from Memphis, Tennessee. Home of the blues & Elvis.
  1. New kilt question from a newbie.
    By staticsan in forum Kilt Advice
    Last Post: 3rd May 09, 06:01 PM
  2. Kilt Question from a Newbie
    By The Kilted Reverend in forum General Kilt Talk
    Last Post: 29th April 08, 06:12 AM
  3. newbie question
    By peverbian in forum Kilt Advice
    Last Post: 26th January 07, 08:31 AM
  4. Maybe a daft question from a newbie, but...
    By porrick in forum General Kilt Talk
    Last Post: 11th May 06, 05:12 AM
  5. Newbie question: What's a tank?
    By ronstew in forum General Kilt Talk
    Last Post: 11th March 06, 04:46 AM
