13th August 08, 07:27 AM
How do I taper for identical hip and waist measurements?
When making a kilt for someone who has identical waist and hip measurements, how do you taper and still keep within the measurements?
Example:
Waist: 38
Hips: 38
Length: 22
If I taper this kilt, will that not throw off either the hip or waist measurement?
13th August 08, 07:40 AM
Gee, sounds like your making a kilt for me. Minus six inches.
13th August 08, 07:52 AM
The measurements may be the same, but people are seldom truly straight up and down. Look for some belly protruding to the front and some rump protruding to the rear -- if you have Barb's book, go back to the part about splitting waist and hip measurements between apron side and pleat side. You may want to put more of the waist measure into the apron side. Then, even if your hip measure is split 50/50, you will have a taper between bottom of fell and waist.
Hope this makes sense!
13th August 08, 08:14 AM
That makes sense. I'm planning to buy Barb's book this month, I'm too anxious I guess. Thanks for explaining it.
13th August 08, 12:29 PM
Won't work. If you tapered the pleats, you'd wind up with the apron measurement at the waist being bigger than the apron measurement at the hips, which would give the apron a reverse taper. Which you don't want.
The only thing you can do here is make a cylindrical kilt.
13th August 08, 12:47 PM
ardchoille,
Are you making a Traditional Style Kilt or a Contemporary Style Kilt?
13th August 08, 07:54 AM
I've been wondering how a kiltmaker would do that, for when I have a kilt made, but was a little afraid to ask... My bottom measurement is almost the same as my top, between thirty-six and seven, but I'm not completely cilendrical.
* I'll keep checking in on this thread...
By Jako Dar in forum Kilt Advice
Last Post: 15th March 08, 04:29 PM
By ScottEPooh in forum DIY Showroom
Last Post: 6th March 08, 05:40 AM
By CameronTaylor in forum How to Accessorize your Kilt
Last Post: 17th October 07, 06:21 PM
By RavenUSA in forum DIY Showroom
Last Post: 11th October 07, 01:13 PM
By dana in forum Contemporary Kilt Wear
Last Post: 10th March 05, 07:41 AM
