Results 1 to 10 of 18
    23rd July 08
    Upstate South Carolina
    Question Kilt Pin Placement
    Hello all,
    Just got my first kilt from Rocky (woohoo!!) And had a question about the placement of the Kilt Pin. The apron has a USA Kilts patch sewn on to the lower corner, about where I thought the kilt pin should go. I kind of like the patch on the kilt though. There's not a whole lot of color on the Clark tartan, and I think the bit of yellow and silver from the patch looks nice on it. The only problem is, the patch doesn't weigh enough to hold the apron down in a breeze.
    Is it ok to wear the Kilt Pin in addition to the little patch on the apron? And if so, where should it be placed? Above the patch, to the side?
    Pictures are in the thread in General Kilt Talk title "It's Here!!"
    thanks for the advice,
    Casey
    17th July 08
    Fayetteville, NC
    Just my taste speaking here, but I personally do not like logos on clothing, period. I would carefully pick it off, and use the kilt pin. Later, if you want more colour, try a pin with a stone set in it, contrasting shirts and hose, flashes and the like. On the other hand, I tend to be more conservative than many. Congratulations, again!
    Quote Originally Posted by Carolina Kiltman View Post
    I agree. Where that damn badge is, the pin should go, and no doubt you know,but just in case you don't, that the pin should only go through the apron and NOT pinned to the cloth below.You do not have to wear a kilt pin, so if you like the badge then leave well alone.
    27th April 08
    Little Rock, AR
    Everything said. I'd take the patch off. Congrates on your new kilt
    30th October 07
    Harrisonburg
    If you like the badge, then keep it; it's your kilt. Perhaps you could brainstorm for ways to weigh down that area of the kilt; maybe you could sew in a small weight under the badge itself. I just think that a pin AND a badge would simply be too much.
    17th July 08
    Fayetteville, NC
    If you decide to keep the badge, carefully cut the threads on the top, and insert something that weighs about 1/2 oz (like three quarters) behind it and sew it up. That will give you the weight. (Just don't use anything that could stain the fabric.)
    13th February 08
    Lakewood, CO
    Quote Originally Posted by TheKiltedWonder View Post
    I think this is a good idea, and would only take a few minutes. You can get seam-rippers for a dollar or two, and just buy a spool of matching thread. Then you could get a small piece of metal, about the weight of a kilt pin (which is only a few ounces) and rip the seam on the patch a little. Slip the piece of metal in and resew the patch (and try to retie knots on the thread that you ripped, otherwise the patch will eventually fall off.) Or you could just take the patch completely off, put the weight under it and resew the whole thing. Just make sure the weight you put underneath the patch doesn't have any sharp edges or points...you don't want it working a hole into your kilt. I love USAK's, but I'm not a big fan of the patch (no offense to Rocky or Kelly!) You could also move the patch up to the upper corner, like SportKilts does, and then wear a regular kilt pin. Just FYI, traditionally a kilt pin is placed about four inches up and two inches in from the bottom and right edges respectively. I usually put mine in that general position, and then center it on the closest vertical stripe or dead-center in the closest "square", depending on the tartan.
    11th July 08
    Home of Texas A&M University
    It's your call, of course. As one who tends toward the kilt pin, I would discreetly lose the badge. But, again, that's my "take" on it.
    Kilted Elder
    Chaplain & Charter Member, The Clan MacMillan Society of Texas [12 June 2007]
    Member, Clan MacMillan International [2005]
    2nd October 07
    Personally (and i don't yet speak from experience as I only have one USAK semi trad) I think the patches in the pictures look pretty good. As to the pin, I have seen them worn all over the edge of the apron, so I doubt anyone would notice if you simply wore the pin beside the patch, or above it, or diagonal to it. I personally have given some thought to the matter, as I plan to get a USAK casual or three or four, myself. So those are the solutions I have come up with- use the pin in conjunction with the patch!
    23rd July 08
    While I like the patch, I really want to use the kilt pin I have. It's one with St. Andrew and his Cross. I think that it really makes a tie-in with the Clark name, and the origins of the family with it's association with the church.
    I think I'm going to try and very carefully remove the patch, and save it, maybe place it on a polo or something, because I do like the patch, and that way I can wear the pin on the kilt, and the patch on a shirt.
    Think I'll wait til tomorrow to try and remove the patch though, steadier hands and all that
    Casey
  1. Kilt pin placement
    By JayFilomena in forum Kilt Advice
    Last Post: 18th February 09, 11:30 AM
  2. Waist Placement
    By davecolorado72 in forum Kilt Advice
    Last Post: 26th February 08, 02:48 PM
  3. Proper Kilt Pin Placement
    Last Post: 29th September 07, 02:40 AM
  4. sporran placement!
    By I M Kilted! in forum How to Accessorize your Kilt
    Last Post: 15th May 06, 08:45 AM
  5. Proper kilt pin placement
    By Geoduck in forum How to Accessorize your Kilt
    Last Post: 16th February 05, 02:28 PM
