Results 1 to 10 of 18
Thread: Aviation Humor
    Southern Breeze's Avatar
    28th August 05
    Chatsworth Georgia, USA
    Smile Aviation Humor
    Aviation Humor
    Pilot of N5000Y: “Five thousand Yankee, 20 miles North of Richmond.”
    Richmond ATC: “Oh no, not again.”
    Tower: “Delta 351, you have traffic at 10 o’clock, 6 miles.”
    Delta 351: “Give us another hint. We have digital watches.”
    “TWA 2341, for noise abatement turn right 45 degrees.”
    “Center, we’re at 35,000 feet. How much noise can we make up here?”
    “Sir, have you ever heard the noise a 747 makes when it hits a 727?”
    From an unknown aircraft waiting in a very long takeoff queue: “I’m f…ing bored.”
    Ground Traffic Control: “Last aircraft transmitting, identify yourself immediately!”
    Unknown aircraft: “I said I was f…ing bored, not f…ing stupid.”
    O’Hare Approach Control to a 747: “United 329 heavy, your traffic is a Fokker, one o’clock, three miles, Eastbound.”
    United 329: “Approach, I’ve always wanted to say this… I’ve got the little Fokker in sight.”
    A student became lost during a solo cross-country flight.
    While attempting to locate the aircraft on radar, ATC asked, “What was your last known position?”
    Student: “When I was number one for takeoff.”
    A DC-10 had come in a little hot and thus had an exceedingly long roll out after touching down.
    San Jose Tower noted: “American 751, make a hard right turn at the end of the runway, if you are able. If you are not able, take the Guadeloupe exit off Highway 101, make a right at the lights and return to the airport.”
    There’s a story about the military pilot calling for a priority landing because his single-engine jet fighter was running “a bit peaked.”
    Air Traffic Control told the fighter jock that he was number two, behind a B-52 that had one engine shut down.
    “Ah,” the fighter pilot remarked, “the dreaded seven-engine approach.”
    Taxiing down the tarmac, a DC-10 abruptly stopped, turned around and returned to the gate. After an hour-long wait, it finally took off.
    A concerned passenger asked the flight attendant, “What, exactly, was the problem?”
    “The pilot was bothered by a noise he heard in the engine,” explained the flight attendant. “It took us a while to find a new pilot.”
    A Pan Am 727 flight waiting for start clearance in Munich overheard the following:
    Lufthansa (in German): “Ground, what is our start clearance time?”
    Ground (in English): “If you want an answer, you must speak in English.”
    Lufthansa (in English): “I am a German, flying a German airplane, in Germany. Why must I speak English?”
    Unknown voice from another plane (in a beautiful British accent): “Because you lost the bloody war.”
    Tower: “Eastern 702, cleared for takeoff, contact Departure on frequency 124.7”
    Eastern 702: “Tower, Eastern 702 switching to Departure. By the way, after we lifted off we saw some kind of dead animal on the far end of the runway.”
    Tower: “Continental 635, cleared for takeoff behind Eastern 702, contact Departure on frequency 124.7. Did you copy that report from Eastern 702?”
    Continental 635: “Continental 635, cleared for takeoff, roger; and yes, we copied Eastern… we’ve already notified our caterers.”
    One day the pilot of a Cherokee 180 was told by the tower to hold short of the active runway while a DC-8 landed. The DC-8 landed, rolled out, turned around, and taxied back past the Cherokee.
    Some quick-witted comedian in the DC-8 crew got on the radio and said, “What a cute little plane. Did you make it all by yourself?”
    The Cherokee pilot, not about to let the insult go by, came back with a real zinger: “I made it out of DC-8 parts. Another landing like yours and I’ll have enough parts for another one.”
    The German air controllers at Frankfurt Airport are renowned as a short-tempered lot. They not only expect one to know one’s gate parking location, but how to get there without any assistance from them.
    So it was with some amusement that we (a Pan Am 747) listened to the following exchange between Frankfurt ground control and a British Airways 747, call sign Speedbird 206.
    Speedbird 206: “Frankfurt, Speedbird 206 clear of active runway.”
    Ground: “Speedbird 206. Taxi to gate Alpha One-Seven.”
    The BA 747 pulled onto the main taxiway and slowed to a stop.
    Ground: “Speedbird, do you not know where you are going?”
    Speedbird 206: “Stand by, Ground, I’m looking up our gate location now.”
    Ground (with quite arrogant impatience): “Speedbird 206, have you not been to Frankfurt before?”
    Speedbird 206 (coolly): “Yes, twice in 1944, but it was dark… and I didn’t land.”
    While taxiing at London’s Gatwick Airport, the crew of a US Air flight departing for Ft. Lauderdale made a wrong turn and came nose to nose with a United 727.
    An irate female ground controller lashed out at the US Air crew, screaming:
    “US Air 2771, where the h**l are you going?! I told you to turn right onto Charlie taxiway! You turned right on Delta! Stop right there. I know it’s difficult for you to tell the difference between C and D, but get it right!”
    Continuing her rage to the embarrassed crew, she was now shouting hysterically: “God! Now you’ve screwed everything up! It’ll take forever to sort this out! You stay right there and don’t move till I tell you to! You can expect progressive taxi instructions in about half an hour, and I want you to go exactly where I tell you, when I tell you, and how I tell you! You got that, US Air 2771?”
    “Yes, ma’am,” the humbled crew responded.
    Naturally, the ground control communications frequency fell terribly silent after the verbal bashing of US Air 2771. Nobody wanted to chance engaging the irate ground controller in her current state of mind. Tension in every cockpit out around Gatwick was definitely running high.
    Just then an unknown pilot broke the silence and keyed his microphone, asking: “Wasn’t I married to you once?”
    In his book, Sled Driver, SR-71 Blackbird pilot Brian Shul writes:
    “I’ll always remember a certain radio exchange that occurred one day as Walt (my back-seater) and I were screaming across Southern California 13 miles high. We were monitoring various radio transmissions from other aircraft as we entered Los Angeles airspace. Though they didn’t really control us, they did monitor our movement across their scope. I heard a Cessna ask for a readout of its ground speed.”
    “90 knots,” Center replied.
    Moments later, a Twin Beech required the same.
    “120 knots,” Center answered.
    We weren’t the only ones proud of our ground speed that day as almost instantly an F-18 smugly transmitted, “Ah, Center, Dusty 52 requests ground speed readout.”
    There was a slight pause, then the response, “525 knots on the ground, Dusty.”
    Another silent pause. As I was thinking to myself how ripe a situation this was, I heard a familiar click of a radio transmission coming from my back-seater. It was at that precise moment I realized Walt and I had become a real crew, for we were both thinking in unison.
    “Center, Aspen 20, you got a ground speed readout for us?”
    There was a longer than normal pause.
    “Aspen, I show 1,742 knots.”
    No further inquiries were heard on that frequency.
    In another famous SR-71 story, Los Angeles Center reported receiving a request for clearance to FL 600 (60,000 ft). The incredulous controller, with some disdain in his voice, asked, “How do you plan to get up to 60,000 feet?
    The pilot (obviously a sled driver), responded, “We don’t plan to go up to it, we plan to go down to it.”
    He was cleared.
    The pilot was sitting in his seat and pulled out a .38 revolver. He placed it on top of the instrument panel, and then asked the navigator, “Do you know what I use this for?”
    The navigator replied timidly, “No, what’s it for?”
    The pilot responded, “I use this on navigators who get me lost!”
    The navigator proceeded to pull out a .45 and place it on his chart table.
    The pilot asked, “What’s that for?”
    “To be honest sir,” the navigator replied, “I’ll know we’re lost before you will.”
    Overheard at Paine Field, Everett, Washington (site of the Boeing 747 and 777 plant). Taylor Air is a flight service at Paine Field. United Airlines was just taking delivery of a brand new 747.
    Taylor Air: “Tower, there is a turtle crossing runway 18.”
    Tower: “Roger Taylor 250. United 35 Heavy, you are cleared for take-off on Runway 18. Caution wake turbulence behind departing turtle.”
    Ah yes, the life of Aviators. "Hours and hours of mind-numbing boredom broken by moments of stark-raving terror."
    However, just as every earth based story starts out with "a guy walks into a bar." every Aviation story must start out with "And this in no s**t".
    5th September 05
    Chicago
    One of my most favorite comments...true in life as well as aviation:
    "The two most dangerous things in military aviation are adrenaline and testosterone."
    Best
    AA
    4 Post(s)
    Quote Originally Posted by Southern Breeze View Post
    As a local I loved this!
    31st December 05
    You can always tell just how good your pilot is when he gives time readouts on the Radio.
    British Air Pilot: says it's 14 hundred hours'
    US Air Pilot : says it's 2 o'clock
    Jet Blue pilot: Mickey's big hand is on the 2.
    15 Post(s)
    A true story.When I was a lad at school we had a Battle of Britain pilot come to talk to us all. He told us a story of how he had Fokkers to the left shooting at him,Fokkers behind shooting at him,Fokkers above,Fokkers below,Fokkers everywhere!He escaped them by flying into the clouds.We of course were trying not to laugh at all this and of course it all ended in uproar!The headmistress,a very straight laced lady,tried to explain that a Fokker was a type of fighter plane, to which there was even more laughter. The killing line,though, came from the pilot "ah yes" said he," the trouble was that these Fokkers were Messerschmitts!" ,to which the whole school collapsed with laughter and made even funnier by the headmistress storming out! The pilot's name was Douglas Bader.
    17th July 08
    Fayetteville, NC
    Quote Originally Posted by Frank McGrath View Post
    We told it as a question of what time is it? The tower asks "What airline are you?", the answer was, "What difference does it make?" The tower responds as above, then adds: For the now defunct Piedmont Airline, "If you're Piedmopnt It's Thursday."
    Still good for a chuckle.
    BTW When Piedmont was taken over, the airline changed its name to US Airways.
    Remember, laughter is good for the body as well as the mind
    31st December 05
    I just flew a Piedmont shuttle from BWI to Philly and back. The DeHavilland said Piedmont right on the side.
    28th August 05
    [QUOTE= Remember, laughter is good for the body as well as the mind[/QUOTE]
    This is why I post these things.
    John Wayne in "The Flying Leathernecks" has the greatest Aviation line ever spoken.
    There he is "And this is no s**t", in the cockpit of his Corsair F-4U when he hears over the radio from his Wingman.
    "Sir, there are Zero's everywhere. We're completely surrounded by them. What do we do?"
    To which The Duke replies, "We're surrounded? Weellll Pilgrim, the first thing we need to do is get all these airplanes into a circle."
  1. Kilted at the Hiller Aviation Museum
    Last Post: 4th March 08, 10:33 PM
  2. Dumfries Aviation Museum
    Last Post: 15th May 07, 05:06 AM
  3. More humor . . .
    By mkmound in forum Miscellaneous Forum
    Last Post: 15th March 07, 06:03 AM
  4. Spirit of Scotland at the Aviation Museum
    Last Post: 24th July 06, 03:49 AM
  5. A Bit of Humor...
    By sav in forum General Kilt Talk
    Last Post: 11th August 05, 10:50 AM
