Results 1 to 10 of 18
    6th November 08
    West Virginia
    knitting my own garters?
    Hey guys,
    Since I am learning and practicing knitting getting ready for Joan's class on kilt hose, it has me thinking about making up a pair of garters. I've seen the snake style ones and ones that look simply flat. My question is this, could I simply make a flat 1" wide "belt" to use and add the decoration tassels to the ends or would I need to make a snake tube type to have enough stretch and durability?
    I was thinking 8 to 10 rows x how ever long I decide to make one an inch or less wide. Figure it would be good practice and a decent goal to do instead of the little squares I am making now lol.
    5th November 08
    Marion, NC
    Quote Originally Posted by runewolf View Post
    The short answer is yes.
    I think if I were knitting garters I would knit them sideways, i.e. on a circular needle, cast on however many stitches you need for the length of the garter, then knit until it's as wide as you want it, approx. 1 inch, then bind off. That should make it not so stretchy, which, to my mind, would be better than having them stretchy. I believe I'd also use as small needles (US 3 or smaller) and worsted weight yarn, so it'll be a really tight knit. That way it'll look more like it's woven, and hold up your kilt hose better.
    If I were making the "Snakes" that Puffer describes, I'd use double-pointed needles, maybe two of them, and knit the garter in the round, with one alteration: I'd cast on half as many stitches as I wanted the finished tube to contain, then knit each stitch, but leave the cast-on stitch on the needle. That'll produce two needles with equal # of stitches on each, and you won't have to sew the end closed. When I got to the end of the garter, I'd work a three-needle bind-off, which is different from a regular bind-off only in that you knit a stitch from both needles at the same time, then pass the previous stitch over it.
    I made a scarf this same way a few years ago, and it's really warm because it's two thicknesses thick, and it doesn't curl on the edges like flat knit does.
    I hope this helps.
    --dbh
    If you know anyone with a knitting machine you can make the tubes, called I-cord on one of them quie quickly.
    Some machines have what is called a garter carriage, and that could be set to make a strip 1 inch wide by up to maybe 200 stitches long - which could be joined together to whatever length is required, if that wasn't long enough.
    Or take one strip and crochet on fancy ends and the fringing.
    Anne the Pleater
    18th January 08
    Gainesville, FL
    This is the coolest thing I'll learn today! That's just brilliant! I'll definitely use that 'trick' on my next stockinette-in-the-round scarf. Thank you!
    5th November 08
    Marion, NC
    I hate to be a wet blanket, but if you have double-pointed needles, you don't need an i-cord maker. You just cast on the desired # of stitches, knit them, slide the work to the other end of the needle, DON'T TURN IT, and keep on knitting. I-cord won't lie flat, though, like Red Raven's garters.
    --dbh
    5th November 08
    Marion, NC
    Quote Originally Posted by idyllicchick View Post
    Thanks for the vote of confidence. It's the same techniques used in making toe-up socks, except with the socks you have to increase at each end.
    This 'trick' will give you a nice chain-looking edge, too. Plus, if you want to add fringe on the ends, you don't have to try to get your yarn needle through a seam, 'cause they ain't one.
    --dbh
    22nd November 07
    US
    I remember James MacMillan had a thread about getting one of those peg style knitting duhickies and knitting garters. He made the fringe by wrapping the yarn around an index card, through the garter end, back around the card, then repeating all the way to the other side. The fringe is then trimmed to the wanted length. I'm guessing he used the same knitting tool that is used on the knitting duhicky to get the yarn through the garter stitches.
    6th November 08
    West Virginia
    Hmm... Interesting thoughts all around. May be a little advanced for me since I am just learning all this hehe. I have seen the i-cord machines at Joannes fabric for less than $10 and never even thought about garters until I started learning to knit. For the kilt hose, I am going to have to find 4 double pointed needles size US5 which is bigger than you are thinking piperdbh. I did find a circular needle in my wife's stuff last night, but never used anything like it... Ideas ideas.... May be fun to play with anyway lol.
    12th May 08
    Isle of Harris
    . For the kilt hose, I am going to have to find 4 double pointed needles size US5 which is bigger than you are thinking piperdbh. I did find a circular needle in my wife's stuff last night, but never used anything like it... Ideas ideas.... May be fun to play with anyway lol.[/QUOTE]
    No you don't I have needles with the kit..........
    6th November 08
    West Virginia
    Ah, thank you Joan, I didn't realize the kit would have the needles in it
  1. Knitting: my new addiction
    By meinfs in forum Miscellaneous Forum
    Last Post: 7th January 09, 12:40 PM
  2. Knitting for Knumptys
    By Weasel Mender in forum DIY Showroom
    Last Post: 11th December 07, 07:46 AM
  3. Traditonal Garters
    By Brian F in forum General Kilt Talk
    Last Post: 26th July 07, 07:39 AM
  4. Sock garters
    By fhpdo in forum General Kilt Talk
    Last Post: 27th January 07, 08:57 PM
  5. Boy Scout Uniform Garters
    By Wompet in forum How to Accessorize your Kilt
    Last Post: 6th April 06, 06:10 PM
