27th February 09, 12:33 PM
Waist Coat Length?
So I oredered a waistcoat and eaton jacket, and my waistcoat is about a 1/2" (2cm) Longer then the jacket. Is this acceptable?
And another quick question... Do argyle or charlie jackets come with god awful shoulderpads like the eaton? Thanks.
27th February 09, 01:00 PM
The waistcoat really shouldn't show below the bottom of the jacket.
As to the second question, I don't really know. Why do they have shoulder pads to begin with?
Sandford
28th February 09, 06:04 PM
 Originally Posted by JSFMACLJR
The waistcoat really shouldn't show below the Why do they have shoulder pads to begin with?
Sandford
Since the site is a uniform company, my guess is that the jackets are intended to be unisex.
28th February 09, 06:16 PM
No... They have male and female Etons, so I guess it's just the style.
I'm not sure exactly how over stuffed the padding is, but I don't think it is an easy task to re-work the shoulders.
28th February 09, 06:45 PM
Shoulder pads are triangular in shape, and held in place at the corners of the triangles. Should be a fairly quick (and therefore not too expensive) job to replace them. Of course ask first.
There is a seam (usually) in the lining from the armseye to the collar in the lining, and would only need a few inches taken out to get at the shoulder pads.
Most fabric stores carry a line of shoulder pads, or they can be made by the tailor shop. Again, not really a difficult task.
28th February 09, 07:02 PM
Changing the pad is easy, but the shoulders were designed around having the extra padding which requires extra fabric and causes a different hang. I guess take it in to the tailor and ask, but that is a thirty-five dollar jacket...
I really wish that this had come up when this spesific jacket had been suggested here on the forum.
27th February 09, 01:04 PM
What exactly do you mean by shoulder pads?
27th February 09, 01:31 PM
Have your local tailor take the over-stuffed shoulder pads out (he will have to replace them with something thinner so the jacket will hold its shape). This will cause the jacket to "drop" about half an inch and your waistcoat should fit perfectly.
28th February 09, 08:34 PM
Excellent advice. waistcoats should be shorter than the jacket.
27th February 09, 01:39 PM
If you would, Dan, name the place from which you have ordered the Eton jacket with over stuffed shoulder pads... So we can avoid the same problem.
Last Post: 6th January 09, 03:48 PM
By Ancienne Alliance in forum General Kilt Talk
Last Post: 31st August 08, 05:55 AM
By Warhoover in forum How to Accessorize your Kilt
Last Post: 25th August 07, 09:05 PM
