Results 1 to 10 of 25
    8th November 08
    Mt. Pleasant, SC/ Hillsdale, MI
    belt loop usage?
    I was kitted out for my first performance with my school's pipe band a while back, and had my kilt belt running through the belt loops on my kilt as would seem to be logical. I then noticed that none of the other drummers or pipers had their belts through the belt loops, and was told that the belt loops weren't for the kilt belt, but only for the sporran strap. I am admittedly a kilt newbie, so I really have no idea whatsoever. What's the deal?
    27th January 05
    Jefferson, Georgia, USA
    For the sake of argument, don't use them for a belt unless you just want to. The belt tends to ride up in the back and if the belt is through the loops the back of the kilt can be distorted. The confusion arises because the loops are 2.5" - 3" wide, perfect for a kilt belt. The intention though is to make it easy to pass a sporran strap through while reaching behind your back, blind. It would be much more difficult to slip it through a 1/2" loop.
    I run my belt through the loops. It's just how I roll.
    29th December 07
    KENT WAQ
    If my kilt has "belt loops", I normally use them.
    1. It keeps the ( in my case ) the belt, in the rear, from riding up over the back of the kilt.
    2. Helps position the sporran strap.
    Puffer
    19th March 09
    Dallas, TX [N 32° 51.288 W 096° 45.978]
    I just discovered last night that putting on a sporran without using the "belt" loops actually stays up! In which case, I don't think I'll be using the loops for either going forward. So much easier this way
    elim
    5th November 08
    Marion, NC
    I don't have belt loops on the kilt I wear, but there are keepers on the one I'm trying to sell, and they're coming loose.
    If you can take them off, it won't jurt anything, and your belt and sporran will stay up just fine without the loops.
    --dbh
    29th March 07
    Edinburgh
    If you kilt is made to measure you should not need (to use) them
    19th March 09
    Astatula Florida
    I'M with "Puffer" on this one, if the Kilt I'm wearing has the "Loops" I use them!
    14th March 09
    when i bought my kilt a few months back it was a option to have loops added so i said yeah why not its free to add em ,
    i just intend to use em for my sporran but with my kilt being a 27-28 inch waist (slinky slinky) i think the belt should sit right without using them but ive yet to get my kilt so time will tell
    8th May 08
    Jacksonville, FL
    Quote Originally Posted by Nervous Jock View Post
    Unless your back is significantly thinner than your hips and your belt keeps riding up off your kilt....
    8th January 08
    The Bayou City - Houston, TX
    Don't use the belt loops for belting. Don't use the hanging loops for hanging. But, do use the leather straps for strapping.
  1. Colorado Fall - Georgetown Loop Railroad
    By rmmcscott in forum Miscellaneous Forum
    Last Post: 17th October 07, 12:19 PM
  2. box pleats compared to knife pleats, cloth usage
    By benkilt in forum DIY Showroom
    Last Post: 27th April 07, 05:08 AM
  3. Fly plaid loop
    By gilmore in forum Kilt Advice
    Last Post: 21st April 07, 12:33 AM
  4. Kilt belt "loop" dimensions please
    By cavscout in forum DIY Showroom
    Last Post: 14th January 07, 01:15 AM
  5. Out of the loop....!
    By Blu (Ontario) in forum General Kilt Talk
    Last Post: 9th May 04, 12:53 PM
