Results 1 to 10 of 10
    10th July 09
    Tapering the fell
    I have searched the forum for this subject and I can't find anything. I am to the point where I am ready to taper the fell and I can't seem to visualize the process of tapering each box pleat. Can someone help me on this? Is there a video tutorial on the subject?
    Thanks
    19th May 08
    Oceanside CA
    Don't know of any visual on the topic but here goes with words.
    From the hem upward to fell, you have 3-inch-wide pleats. From fell to waistband, you want to decrease that 3 inches to some lesser width (based on your waist measurement).
    You should have chalk lines marking that 3-inch width. Below the fell, each pleat is folded along that chalk mark. Above the fell, fold the pleat so that the chalk mark is hidden inside the pleat -- by 1/2 the amount that you need to decrease. For example, if you are tapering/decreasing a pleat by 1/2 inch, the chalk mark on each side of pleat should be 1/4 inch inside the fold. Pleat width at waist is now 2.5 inches (3 minus 1/4 on left and 1/4 on right). Make sure folded edge of one pleat continue to butt up against the folded edge of the next pleat all the way from fell to waistband.
    Hope this helps!
    10th July 09
    So I don't just overlap the pleats? I am still a little hazy on this. I am going to try what I think you said and see if it works.
    29th April 07
    Columbia, SC USA
    Quote Originally Posted by kd0afk View Post
    They will overlap on the inside...
    On the "right side" we want a straight, more or less neat topstitched seam
    16th January 06
    London
    just a point of clarification, make sure you know the difference between BOX pleats and KNIFE pleats
    Box pleats wouldn't be overlapped, but Knife ones would!
    10th July 09
    Fluter, thanks a million. That is exactly what I was picturing based on Sydnie7's post. Just to make it crystal clear, If I want to take off a half inch on a box pleat I would make a mark 1/4" in from both sides at the waistband (this becomes my new pleat line from the fell up, crease and iron on the new line and overlap the excess on the inside and butt the new creases together just like they were before.
    I have started to make 2 other Util's before this one and I do believe that I like the box pleat better.
    I will post photos of the finished product when I am done.
    Thanks guys.
    Yessir. That's exactly what you do.
    6th July 09
    Franklin, Ohio
    Thats exactly how I did it .... made sure my pleat was 3 inches across and looked straight... then measured each side and made my new lines and folded overlapped/pinned/sewed down
    Here it is graphically.
    19th May 08
    Oceanside CA
    Words from a writer and schematics from an engineer, fortunately we all agree about the process! Ask a question on XMarks and you'll get answers to suit every learning style
  1. Knife-pleat tapering info
    By Phicong in forum DIY Showroom
    Last Post: 14th September 07, 09:10 AM
  2. sew fell up or down
    By auld argonian in forum DIY Showroom
    Last Post: 14th May 07, 10:14 AM
  3. A tapering nightmare.
    By Erisianmonkey in forum DIY Showroom
    Last Post: 28th March 07, 02:18 PM
  4. Honey, the dog fell in the moat again!
    By Shay in forum Miscellaneous Forum
    Last Post: 27th February 06, 03:20 PM
  5. the old fell-in-stillwaters question
    Last Post: 23rd November 05, 12:19 PM
