Results 1 to 10 of 14
    16th August 06
    Dallas, Texas, USA
    Kilt Pin Position
    Hi all,
    I was wondering what the opinions are regarding kilt pin position.
    I have read where certain military units (UK) have worn them fairly high up the apron; not at the 'foot,' as it were. I have also read about a "hand's breadth" from the bottom of the apron. It appears that there are some differences. The Regimental Drum Major Assoc. gives much guidance on uniform, but the kilt pin position is not given explicitly. I wonder how much is left up to individual interpretation?
    [just fyi, I wear my pin in the geometric middle of the green crossings of one sett in the Black Watch kilt]
    Thoughts?
    22nd September 08
    Aberdeen/Huntly, Scotland
    I wear my pin a wee bit up and a wee bit in from the bottom right hand edge of the apron depending on the tartan and the pin ive found this to work well for me
    Jordan
    The hielan' man he wears the kilt, even when it's snowin';
    He kens na where the wind comes frae,
    But he kens fine where its goin'.
    There is no hard and fast rule on this subject, although, towards the bottom of the kilt and maybe an inch to two inches in from the edge would be the norm. Mid thigh height is also an option, but in reality, wear your pin wherever it suits your taste. Remember not wearing a pin at all, is also an option.
    15th May 05
    Pullman, Washgton
    May I suggest that you wear your pin very near the fringe as the material is doubled over there and less likely to be damaged by the weight of the pin.
    27th July 09
    Greendale, Massachusetts, Unites States
    I've found that a pin's-width from the edge, and a pin's-length from the bottom looks good and balanced to me.
    7th May 09
    Oslo, Norway
    I've recently copied Ancienne Alliance and worn a round or egg-shaped pin about mid-thigh and two fingers from the fringe.
    To me the pin makes no difference in the function of the kilt, it's purely decoration.
    Vin gardu pro la sciuroj!
    20th May 07
    Madison, WI
    Quote Originally Posted by Sir Robert View Post
    I try to position my kilt pins where the apron is folded under as well. However, I know at least one of my kilts has a very narrow section of folded apron material and would cause the pin to be too close to the edge of the apron. As a general rule, I also like to place my kilt pin with reference to the tartan (in the middle of a sett line, for instance)
    [B][U]Jay[/U][/B]
    [B]Clan Rose[/B]-[SIZE="2"][B][COLOR="DarkOrange"]Constant and True[/COLOR][/B][/SIZE]
    [SIZE="1"][I]"I cut a stout blackthorn to banish ghosts and goblins; In a brand new pair of brogues to ramble o'er the bogs and frighten all the dogs " - D. K. Gavan[/I][/SIZE]
    8th January 08
    The Bayou City - Houston, TX
    When I wear one, I position it about 4 inches up and 2 in. And, the older my back gets, the higher the pin will go.
    3rd August 07
    New York City
    I have seen an episode of a British TV show from the 1960's which depicted a kilted regiment, where the actors all had the pins mid-thigh. It puzzled me at the time, as I had never heard of wearing the pin that high, but it does seem to be a common military practice.
    14th June 08
    Near Glasgow
    I think that idea is because if the pin was actually put through both layers of material to stop it blowing up in the wind, as history would have you believe, then if it was too low down, it would restrict your movement a bit. It'd almost certainly result in a ripped kilt if you were giving it plenty during a Dashing White Sergeant, for example.
    So, even though it's only cosmetic rather than functional, it makes sense to some folk to pin it where it would be pinned if it were functional.
    Mind you, this is based entirely on what I was told by the nice man at Redshank in Inveraray who made my kilt, but it has a certain plausibility to it!
  1. Where and how do you position a kilt pin?
    By scotchmaster in forum How to Accessorize your Kilt
    Last Post: 29th January 09, 11:30 AM
  2. Velcro position
    By Mipi in forum Kilt Advice
    Last Post: 23rd May 08, 05:20 AM
  3. What's Your Position on Flashes?
    By Jack Daw in forum How to Accessorize your Kilt
    Last Post: 29th February 08, 05:39 PM
  4. Kilt Pin Position
    By AnimalK in forum How to Accessorize your Kilt
    Last Post: 24th November 06, 10:00 AM
  5. kilt pin position: Vert. / Horiz.?
    By jjoseph in forum How to Accessorize your Kilt
    Last Post: 8th July 05, 12:14 AM
