Results 1 to 10 of 16
    MacBean is offline Oops, it seems this member needs to update their email address
    21st October 09
    Valley Forge, PA (USA)
    First Time Kilt Help
    I just got my new casual kilt back from alteration at Burnetts & Struth, and have a really, silly question. The pleats are sewn together at the bottom: is this just for shipping and should I remove them? The front has a small bit of wrinkling from the shipping; how should I press this best? OK, that was two questions.
    I must say they have been helpful and friendly through my confused purchase and alteration; I have to recommend them highly. I might normally have bought from USA Kilts as I am in the same town as they, but Burnetts & Struth had a real deal on ancient MacBean casuals.
    13th June 07
    Hoschton, GA
    13 Post(s)
    I'm sure it will only be minutes before you get the same advice from many, however, press any wrinkles from shipping before youremove the basting stitches. Then remove the basting stitches holding the pleats in line, (they are only there for shipping purposes. Congatulations on your new kilt!
    All the best,
    David
    “If you want people to speak kindly after you’re gone, speak kindly while you’re alive.”
    Bob Dylan
    21st October 09
    thanks David...that was easy...
    22nd March 09
    Savannah, GA USA
    You'll find that hanging your kilt up and hitting it with a clothes steamer periodically will do wonders to relax the wrinkles that come from normal wear. If you don't have a steamer, I'm told that hanging your kilt in the bathroom when you take a steamy shower can do the same trick.
    14th January 08
    San Antonio, TX
    Press any wrinkles in the PLEATS before removing the basting stitches which are just holding the pleats in position for transport. Make sure the thing fits right around your waist and hips before removing the basting, however, as if it does not fit you will want to leave the basting in when you send it back for a refitting. If the only wrinkles are in the Aprons you can usually iron those out with a good steam iron by flipping the kilt inside out and placing a bath towel on top of the kilt, which should be on top of your ironing surface. Iron the aprons smooth throught the towel with lots of steam, then hang that baby up to let it set up as the steam cools and dries. Repeat as needed. If you need to iron the aprons leaving the basting stitches in helps to make the rest of teh kilt a lot less unwieldy, so iron whatever you have to, make sure it fits and looks good, then remove the basting.
    Enjoy. B&S make a nice casual kilt. I have one in Weathered MacDonald.
    3rd January 08
    Illinois, USA
    4 Post(s)
    You've already received all the advise you need on the basting stitches, so I'll just add congratulations on your new kilt. Wear it with pride.
    Member Order of the Dandelion
    21st October 09
    (knocks himself upside the head)... OK, it's like a sack of rice; undo it on one end and the whole baste stitch comes off in one fell swoop (whatever that is). I was going at it with a magnifier and stitch cutter. I will say that the weaving looks fine under a magnifier!
    I have a tweed kilt jacket, but for fun, tried on all my other jackets. Colorwise, I really liked blue blazer with ancient MacBean, so maybe I'll get one of the old blazers converted. I wonder if the slit in the back middle matters for a kilt jacket?
    24th June 09
    Kamloops BC
    I think you'll find that the single vent at the back will gape open when the jacket is converted. When I had one done the tailor closed up the single vent and put in two, one on each side of the back. Looks and hangs much better now.
    Laurie
    The secret of happiness is freedom,
    and the secret of freedom, courage
    Thucydides
    23rd August 08
    Quote Originally Posted by Standard View Post
    That pretty much sums up what I was going to say.
    bricelythgoe is offline Membership Revoked for repeated rule violations.
    7th January 09
    Pictures, my friend, pictures. Nothing happened unless there is evidence..
  1. First Time Kilted at Work Today.....Crazy Time....
    Last Post: 23rd February 07, 10:47 AM
  2. Big Time Jones for a Short Time...
    By Captain in forum General Kilt Talk
    Last Post: 18th December 06, 01:19 PM
  3. First time/First kilt
    By Juggalotus in forum Kilt Board Newbie
    Last Post: 25th August 06, 11:47 AM
  4. Long time wearer, first time poster.
    By beloitpiper in forum Kilt Board Newbie
    Last Post: 5th July 06, 02:35 PM
  5. First time out in a kilt
    By Rusty in forum General Kilt Talk
    Last Post: 12th April 06, 01:00 AM
