31st January 10, 10:14 PM
What is "fusable interfacing" and who uses it to make kilts?
I've run into this terminology around here lately; and, I'd like to understand it better.
Thanks for your input!
The spirit of the Declaration of Arbroath (6 April 1320) abides today, defiantly resisting any tyranny that would disarm, disperse and despoil proud people of just morals, determined to keep the means of protecting their families and way of life close at hand.
31st January 10, 11:01 PM
Interfacings are using in making garments to give the fabric body, to strengthen weak fabrics and/or to give reinforcement to parts that need support such as buttonholes.
Interfacings are used under the main fabric, usually applied to a facing, but can be applied directly to the main fabric.
Interfacings can be made of any fabric, but usually (these days anyway) are made from a non-woven fabric. Bespoke tailoring will most likely use sew-in interfacing rather than fusibles.
Fusible interfacings have a heat sensitive resin on the wrong side so that you can apply the interfacing to the garment fabric using an iron.
1st February 10, 07:59 AM
There are three sorts of interfacing construction. There are non-wovens, which are mostly needle-punch felted. these tend to be stable in all directions, which means no stretch. there are some all-bias (stretch equally in all directions) variants around. There are woven interfacings, which are usually stable warp (length) wise and weft (width) wise, but strech on the bias. There are knit (usually, but not exclusively tricot) interfacings. They've got various stretch properties, usually they're stable one way and strech the other. They're usually more flexible, so they drape better. There are weft and warp insertion interfacings, which are knit, but then have a weft or warp thread inserted into them. Less stretch, and less flex.
1st February 10, 09:21 AM
This is not an interfacing. Stitch Witchery is what's called fusible web and used as you described.
regardless of Dixiecat's points (because in time the fusible does leave a dimpled surface after time and sewn in doesn't)
I can only assume that you've used low-quality fusibles and/or applied them incorrectly and/or used the wrong fusible for a project. I have made quite a few garments using these products and have had no problem with them when used properly. I'm totally serious.
And yes, the answer really is, don't use fusibles in kiltmaking!! The best product is the hair canvas.
31st January 10, 11:06 PM
It's a lazy man's interfacing. Less stitching, doesn't last as long or work as well.
31st January 10, 11:12 PM
oh, man! Finally a question I can answer, and Dixiecat beat me to it. That's it, I'm never logging out of Xmarks...
1st February 10, 12:10 AM
Not true. Works great when used properly and for the right projects. There are certain projects I wouldn't use it for, but for 90% of garment sewing and craft projects, it's better than sew-in interfacing.
1st February 10, 12:11 AM
Okay, so it doesn't work as well for me. I am also by no means a tailor.
1st February 10, 12:12 AM
I also have trouble setting the coffee maker.
1st February 10, 12:47 AM
Neither am I.
Here's my 'rules' for interfacing:
1) match the weight of the interfacing to the weight of the fabric. Generally, the heavier the fabric the heavier the interfacing
2) match the weight of the interfacing to the 'presentation' that you wish to achieve. -you may wish to have crisp collars and cuffs so use a stiffer weight than what you put in the button band of the shirt
3) test several weights of interfacing with your fabric to see which is best
4) pre-shrink your interfacing before using -place the interfacing in a basin of hot water (hand hot, not boiling hot) and let cool, gently squeeze out the water and hang over the shower rod to drip dry
5) never 'iron' on the interfacing, always 'press'. This means use an up/down motion with the iron, never sideways or back/forth.
By Howard Clark in forum General Kilt Talk
Last Post: 26th April 09, 06:04 AM
By Phogfan86 in forum General Kilt Talk
Last Post: 6th April 09, 09:56 AM
By S.G. in forum General Kilt Talk
Last Post: 7th September 07, 02:50 PM
