Page 1 of 4 123 ... LastLast
Results 1 to 10 of 35
Thread: Lost my sgian
    27th May 05
    Lexington KY
    Lost my sgian
    Went to put my antique sgian dubh in the hose Saturday and couldn't find it.
    I've searched for hours since, emptied drawers, pulled every piece of luggage out, scoured closets, grilled family but I am afraid it is gone. I'm gutted. I spent a long time looking for just the right one, and spent a fair sum obtaining it and now I've lost it. Haven't lost a knife since I was a kid
    I even woke up at midnight with a new idea where to look, but failed again.
    Sympathy please, and if you know any incantations that will make it miraculously reappear by all means start chanting.
    David
    8th January 08
    The Bayou City - Houston, TX
    Do you remember removing it from your hose the last time you were done with it?
    3rd July 09
    Canada
    If I recall correctly, there is an ancient Ulster method of recovering lost knives, found in the book Tom Sawyer. Tom uses it or talks about it. Hopefully you lost it at home and it's just the Little People hiding it to have you on for a while.... But this why I shove my valuable sgian way down in the hose when I'm out and about, since the Big People are less likely to relent once they have something
    5th September 05
    Chicago
    Did you remove it from your sock somewhere along the way because it was catching on something or encumbering you in some way? Possibly in the car while driving? I assume that you checked wherever it is that you usually get undressed...bathroom, bedroom...
    My experience with stuff that I lose is that I put it somewhere "temporarily" thinking that I'll just pick it up in a little while and put it back where it belongs. These days this includes coffee cups, screwdrivers, cd's...I'm still looking fo a couple of enlarger lenses that I put "in a safe place" a couple of years ago and can't remember where the safe place is...
    Good luck. Hope it's not the beginning of CRS* syndrome...
    Best
    AA
    *Can't Remember S#!+
    3rd July 09
    Canada
    I found the Tom Sawyer reference, Tom Sawyer Chapter VIII, good ol' Google. I see it was for lost marbles but there was a knife involved. No harm in trying it, pasting it here-below:
    " He went to a rotten log near at hand and began to dig under one end of it with his Barlow knife. He soon struck wood that sounded hollow. He put his hand there and uttered this in- cantation impressively:
    "What hasn't come here, come! What's here, stay here!"
    Then he scraped away the dirt, and exposed a pine shingle. He took it up and disclosed a shapely little treasure-house whose bottom and sides were of shingles. In it lay a marble. Tom's astonishment was bound- less! He scratched his head with a perplexed air, and said:
    "Well, that beats anything!"
    Then he tossed the marble away pettishly, and stood cogitating. The truth was, that a superstition of his had failed, here, which he and all his comrades had always looked upon as infallible. If you buried a marble with certain necessary incantations, and left it alone a fortnight, and then opened the place with the incantation he had just used, you would find that all the marbles you had ever lost had gathered themselves together there, meantime, no matter how widely they had been separated. But now, this thing had actually and unquestionably failed. Tom's whole structure of faith was shaken to its foundations. He had many a time heard of this thing succeeding but never of its failing before. It did not occur to him that he had tried it several times before, himself, but could never find the hiding-places afterward. He puzzled over the matter some time, and finally decided that some witch had interfered and broken the charm. He thought he would satisfy himself on that point; so he searched around till he found a small sandy spot with a little funnel-shaped depression in it. He laid himself down and put his mouth close to this de- pression and called --
    "Doodle-bug, doodle-bug, tell me what I want to know! Doodle-bug, doodle-bug, tell me what I want to know!"
    The sand began to work, and presently a small black bug appeared for a second and then darted under again in a fright.
    "He dasn't tell! So it WAS a witch that done it. I just knowed it."
    He well knew the futility of trying to contend against witches, so he gave up discouraged. But it occurred to him that he might as well have the marble he had just thrown away, and therefore he went and made a patient search for it. But he could not find it. Now he went back to his treasure-house and carefully placed himself just as he had been standing when he tossed the marble away; then he took another marble from his pocket and tossed it in the same way, saying:
    "Brother, go find your brother!"
    He watched where it stopped, and went there and looked. But it must have fallen short or gone too far; so he tried twice more. The last repetition was successful. The two marbles lay within a foot of each other."
    MacKay71's Avatar
    MacKay71 is offline Oops, it seems this member needs to update their email address
    12th March 08
    Jonesboro, Georgia
    Once mine fell onto my boot!
    Scott D McKay
    8th January 10
    Pinckney, Michigan
    "Tony, Tony look around......somethings lost that can't be found......."
    Did that help? Always seems to works for my wife.
    With as much as it means to you, I'm sure that you would have noticed it if it were missing when you last undressed. I often have the same problem as Auld Argonian, thinking I found a safe temporary location to put something. Sometime the most obvious places get overlooked easily. Me being 6'4" I often put things up high...top of the fridge or book case. A time or two it was in the frigde. Don't ask. He refers to it as CRS for me similar to Alzheimer's but known as Anheuser's
    I have done the same as I feel for you and truly hope that it turns up soon.
    11th January 09
    North Ridgeville, Ohio
    Check the dryer that is the first place I look for ANYTHING I have loss-ed.
    Santa Kona
    Founder & Chairman of Clan Claus Society
    Chieftain Clan Kennedy
    13th December 07
    Midvale, Utah
    Having to hunt down my sgain time and time again, I now put my sgain in my sporran when I'm not wearing the kilt. Since I only have two sporrans, it's an easy search as they both hang on the same hook in the closet.
    Hope you find it!
    Earl D-
    Clans Cameron and MacLeod
    I thought I had a handle on life-then one day the handle broke off!
    20th January 10
    AZ
    Quote Originally Posted by Santa Kona View Post
    Hopefully not in the dryer...it may have shrunk!
  1. We lost Phoenix
    Last Post: 23rd February 10, 08:10 AM
  2. For all of us who have lost a pet
    By Jerry in forum Miscellaneous Forum
    Last Post: 24th May 09, 07:35 AM
  3. He's lost it!
    By rollerboy_1979 in forum General Kilt Talk
    Last Post: 19th November 07, 08:14 AM
  4. I lost my cool
    Last Post: 28th June 05, 11:55 AM
