Results 1 to 10 of 10
    1st December 08
    Montgomery Alabama
    6 Post(s)
    How small is too small-box pleated Black watch
    Your wisdom is requested.
    I have some very heavy 18 oz double wide BW which is enough to make a knife pleated kilt or two. I was thinking that, persuaded by Matt Newsome's arguments, a 4 yrd box-pleated kilt would be a good summer wear addition, lighter but enough Substance to Swish (STS parameter). The material is indeed beautiful.
    Having never pleated to stripe I was anxious to do that. Splits are 21.5 / 19.5 and 21.5/22.5. The sett is 5 3/8" (136mm) and if I go one a sett (ie strip) then I get 12 pleats but only 45 mm wide (less than 2 inches by 6 mm). If I go to the recommended method: 1.5 setts I get 8 pleats of 2+ inchs per pleat and the pattern "approximates" the sett.
    MY QUESTION:
    how important is the "no pleating less than 2 inches" rule for the box pleat?
    8 large pleats sounds unattractive compared to twelve smaller ones. This is my 3rd kilt.
    May you find joy in the wee, ken the universe in the peculiar and capture peace in the compass of drop of dew
    30th March 05
    Kentucky
    It's not crucial to not have pleats less than 2" wide, but I think in a box pleat, they really do look better when they're wider.
    I have a Black Watch from heavy weight material (either 18oz or 21oz, don't recall). I box pleated it, and the pleats are 2.25" or so at the hips, 2" at the waist, pleated to the sett. It looks pretty good pleated that way, and I wouldn't really want pleats much narrower than that (in a box pleated kilt)
    From information gleaned from studying pleat shots - (just for educational purposes of course), the box pleated kilt is normally composed of panels with a strong feature of the sett placed centrally, being the visible face of the inverted pleats.
    There are far fewer panels than is usual in a knife pleated kilt, and as the panels taper towards the waist usually the shaped edges are placed in a fairly featureless part of the sett so as not to draw attention to vanishing or narrowing stripes.
    I believe that I have seen box pleated kilts with just six panels - perhaps even as few as five, though the search feature might bring up any number of photos, and I am sure those fortunate enough to have had box pleated kilts made for them by the experts will provide more information.
    25th May 06
    Kitchener, Ontario, Canada
    Quote Originally Posted by WClarkB View Post
    MY QUESTION:
    Are you sure your measuring the sett correctly? 5 3/8" seems incredibly small for 18 oz. Black Watch. Black Watch in that weight is only readily available from two mills: Robert Noble and the House of Edgar. I can't recall the repeat size on Noble's fabric off-hand, but on the House of Edgar's 18 oz. Black Watch it is 34 cm (about 13.4 inches.).
    People often make the mistake of measuring Black Watch by measuring from one black line within the green to the next. Is this what you've done? You need to also include the blue sections; the one with a single set of tramlines and the next with the double set. So, the repeat would be green section, single black tramlines set in blue, green section, double black tramlines set in blue, green section. Does this make sense?
    Owner/Kiltmaker - Keltoi
    M. A. C. Newsome is offline
    INACTIVE
    Contributing Tartan Historian
    26th January 05
    Western NC
    The problem with narrow pleats in a traditonally made 4 yard box pleated kilt is that the depth of the pleats is only approximately half of the width of the visible pleat reveal. So a 2" wide pleat is only 1" deep, in other words.
    Any pleat more narrow than 2" will have a very shallow pleat, and it will be much more difficult to get it to maintain its shape.
    Of course you can have a more narrow box pleat and not necessarily sacrifice pleat depth by including more yardage in the kilt. In this case the pleat on one side of the pleat will be rather deep, and the other side will be shallow. This is, in essence, the "military box pleat" of today.
    There is nothing wrong with having 8 pleats. Most of my personal kilts have either 8 or 9 pleats. Looks perfectly fine in a box pleated kilt.
    1st December 08
    Montgomery Alabama
    6 Post(s)
    Quote Originally Posted by slohairt View Post
    ooops huhhhh! (strikes forhead repeatedly after looking for the tramlines) correction 10 7/8 inches. Thank you from the bottom of my (rather dense and unobservant ) heart.
    walt
    1st December 08
    Montgomery Alabama
    6 Post(s)
    ahh, had not thought of the depth factor and that does explain rather well the reason for the oddness of the military box pleat. As it is I completely missed the actual sett size (vide supra) so it is back to the drawing board and your recommendations (ie to the 3/4 sett in this size) BTW it was indeed a pleasure to meet you if ever so briefly at Stone mountain.
    walt
    7th July 06
    Roswell, Georgia USA
    I have an 18 oz. box pleat in Gordon. The set repeat is 14 inches and as it is BW based, You might measure again, from single tramline to single tramline. The pleats are about 2 inches wide, and there are 11 of them.
    18th February 05
    Spokane, WA
    I usually study the sett and decide what will work well. If you're pleating to stripe there is no reason that you can't pleat to two different strips as long as you have enough depth, or maybe you might do that to get enough pleat depth. You might also try to do a double box pleat.
    31st May 08
    dc
    I know you've resolved this question already but I wanted to comment on your statement: "8 large pleats sounds unattractive compared to ..."
    I've made about seven or so box-pleated kilts that have 6, 7 or 8 pleats of about 3 inches wide. They are certainly not unattractive! Here's a recent example.
    Good luck with your Black Watch project.
  1. Kilt too small - what to do...
    By Stilletto_Rebel in forum Kilt Advice
    Last Post: 9th December 09, 08:34 PM
  2. SMALL world
    By beloitpiper in forum General Kilt Talk
    Last Post: 7th October 09, 06:22 AM
  3. Small Black Watch tartan remnant needed
    By 1oldsarge in forum DIY Showroom
    Last Post: 1st April 08, 07:48 PM
  4. Small Argyle
    By keith_b in forum USA Kilts
    Last Post: 15th October 07, 01:20 PM
  5. It's a Small World
    By Casey in forum General Kilt Talk
    Last Post: 10th June 04, 02:16 PM
