2nd November 10, 01:57 PM
Review My Attire (Black Tie)
As some may know, I'll be headed to my first Tartan Ball shortly, and have finally assembled my outfit. I formally submit it to the rabble for critique.
I'm wearing my Argyll jacket, and have purchased a 3 button waistcoat to go with it and bump it up in terms of formality.
Shirt is a plain fronted pique with turn down collar.
Tie is black silk (and self tied). Studs and cuff links are silver knots.
Sporran is skunk - and the sibling to the one I made HERE for ShaunMaxwell. I know most here would prefer to see a metal cantle, but I can't abide stamped/chromed pieces, and there are no pewter ones I like until I have time to start casting my own.
The kilt pin is a small silver penannular I picked up on eBay
Hose are actually navy, but read as black in the pic. Red garter ties.
Shoes are toe capped Oxfords, which still need a mirror polish before the big 'do'. I just want to break them in a bit more first.
Everything will need a final press or steam before the big day.
The only thing I don't have in the shot is a linen handkerchief in my breast pocket... I think my son may have them secreted away somewhere.
So, what does the rabble think.
As a note, I may switch kilts and go with the Wallace Red, in which case I'd probably go with the bottle green hose and red garters, but this is probably an outside chance.
2nd November 10, 02:02 PM
Looks great! I really like the three-button waistcoat. Classy.
The only suggestion for the future I would make is to invest in a pair of Argyll or Diced hose (maybe you can work out a trade for a sporran?). If you went with Red/Black diced you could wear them for either the Wallace or the Baird kilt.
Have a great time!
David
2nd November 10, 02:11 PM
I think it all looks fine, but I have two thoughts:
1) I prefer my kilt pin lower down on the apron, just because I think it draws more attention than if it's pinned high up, like you have it. However, if you like it pinned high, then pin it high.
2) I'd switch to red hose (just because I like red hose), and I think it would "bring out" the red stripe in the tartan.
If you keep everything the way it is, you'll still be the best-dressed patron of the ball.
--dbh
2nd November 10, 02:15 PM
I'm no expert, but from what I've gathered around the forum, you look correct and appropriate. What's more, you look good!
What about a sgian dubh? If you're wearing one, apologies because I can't see it.
- An t'arm breac dearg
Perfect!
The only change I would recommend would be a pair of diced or tartan hose. While navy isn't black ( which I do not like ) it can look black under certain conditions.
I wish more people would wear black Argyll jackets in the evening instead of PC coatees. Well done for not going in that direction!
2nd November 10, 02:21 PM
I'm a big fan of the argyll with waistcost for black tie events. To me it's a better equivalent of the American black tie tuxedo than a PC (which always seemed like a white tails equivalent.) Nothing overstated. James Bond from the waist up and Sean Connery from the waist down.
You could go the diced hose route if you wish, but it's something that's likely to draw more attention. You may or may not want to be conspicuous on this occassion.
I can't find any fault with this at all...can't even say you should get a haircut.
The kilt pin could be a bit lower, but the pin itself is great.
You could option diced or argyle hose, or maybe hose tops, but what you have is outstanding! And bravo for the hose ties instead of flashes...very classy.
Allen
2nd November 10, 02:28 PM
Sharp dressing. Me, is the waistcoat has pockets, maybe a pocket watch and chain(?). I don't know about the kerchief in the pocket, maybe if there was a with/without. But still looks good as is.
Chris Shepherd
PS Still jealous (jonesing) of that sporran
2nd November 10, 02:39 PM
 Originally Posted by JSFMACLJR
Perfect!
*** Perfect, indeed. *** for black Argyll instead of PC coatee. I am a little more comfortable with your choice of Navy hose than Sandy, but his point is quite well taken. I further agree with the recommendations of the previous posters that you consider diced or tartan hose for the future. While hand knit will be your ultimate goal, J Higgins sells perfectly serviceable machine knit diced hose for $ 60, available here: http://www.jhiggins.net/sf_proddetai...39H51F6K1QVR78. My view is that the black and red are the most universally compatible...
While you consider the diced/tartan hose options, the outfit you have on is perfect as is, and you are good to go. You look smashing, and should stride forth proudly!
"Before two notes of the theme were played, Colin knew it was Patrick Mor MacCrimmon's 'Lament for the Children'...Sad seven times--ah, Patrick MacCrimmon of the seven dead sons....'It's a hard tune, that', said old Angus. Hard on the piper; hard on them all; hard on the world." Butcher's Broom, by Neil Gunn, 1994 Walker & Co, NY, p. 397-8.
By CMcG in forum Kilt Advice
Last Post: 4th October 10, 07:00 AM
By KFCarter in forum Kilt Advice
Last Post: 1st September 10, 08:58 PM
By Jock Scot in forum Kilt Advice
Last Post: 28th August 10, 01:47 PM
By JSFMACLJR in forum Kilt Advice
Last Post: 17th August 10, 05:37 PM
By Tiny in forum Kilt Advice
Last Post: 3rd August 10, 03:13 AM
