Results 1 to 10 of 23
    10th February 08
    Doniphan, MO
    Kilt Pin Round 2
    If you recall I made a kilt pin the other day using wood (specifically black ebony) and today I decided to make another one using a purple and green acrylic to make my version of a thistle. I still have to flatten a spot for the pin itself but this is what I have today. It is about 2.5" long.
    Be honest in your review, I'm a Scot and am, therefore, thick skinned.
    "just as the Son of man did not come to be served, but to serve, and to give His life as a ransom for many." Matthew 20:28
    Clan Maclachlan
    Clan Hanna
    8th November 10
    Nice
    I think it looks great, very unique and eye-catching. May I ask you a question? I've recently made some kilt pins, but am having trouble with the backing, mainly that I can't find any of the pin components that are longer than 1 1/2 inches, or ones that don't roll and allow the pin to flop over instead of laying nice and tight against the kilt. Any suggestions?
    14th November 10
    North of Detroit...hard by Lake St. Clair
    "having trouble with the backing, mainly that I can't find any of the pin components that are longer than 1 1/2 inches, or ones that don't roll and allow the pin to flop over instead of laying nice and tight against the kilt. Any suggestions? " I second the question! ;)
    7th July 10
    Columbus, Ohio, USA
    That looks fantastic! I too have a question! When are you going to start taking orders!
    12th May 09
    Southwest Missouri
    One possible answer: forget the pin back and make some little spikes which will accept a clutch back like most military uniform stuff. I have even used the lowly thumbtack by grinding the round head to the size I wanted and scoring the shaft a bit so the clutch back has something to grab.
    Roughen the head somewhat and they can be epoxied onto a lot of stuff. Not sure about plastic, though. Maybe some other kind of glue would work.
    They have the advantage of setting your object back close to the fabric so it doesn't flop. I have a Masonic kilt pin which I may strip the pin back off of and replace for just that reason.
    Dan
    4th January 10
    Tennessee
    I've been wondering if you could cut it length wise and end up with 2 pins.
    It wouldn't stick out so much on the kilt and would be less likely to roll or get hung up on something. It would also give you a surface to mount the pin on.
    It's beautiful, by the way. Very nice.
    10th February 08
    Doniphan, MO
    Quote Originally Posted by Eleazar View Post
    I actually like that idea! I think the next round instead of tapering it as much I can start with a larger version (diameter wise) and then split it using the band saw. From there I can drill and epoxy a pair of pins for the clutch backs (great idea, Dan!).
    Clan Maclachlan
    Clan Hanna
    10th February 08
    Doniphan, MO
    Quote Originally Posted by TheKiltedChaplain View Post
    1.5" is all I have been able to locate but I had another idea as I was sitting here looking at the Hunter Ed Instructor badge...it has a thin but very strong magnet glued to it and a small piece of steel that is used under the shirt that might be much better than even the pin/clutch method and will prevent having to poke holes in the kilt! Something along these lines...
    Clan Maclachlan
    Clan Hanna
    10th February 08
    Doniphan, MO
    Quote Originally Posted by CaseyB View Post
    I'm not sure what I would even think about charging for one of these. The material cost truly is negligible, it is the labor involved in all of this! This one pin (which will now become two thereby reducing work time by half) took the better part of an hour spinning on the lathe turning and then polishing.
    Hand made and every one would be unique. Assuming I made one as Mark said, split in half and then offered it up with the magnetic back, what it would be worth to a buyer is the question.
    Clan Maclachlan
    Clan Hanna
    4th January 10
    Tennessee
    I believe I would be interested in one.
    There is an old turners trick where you use double sided tape to hold the turning together. Then when you are done, a quick smack on the line where the tape is and you have two mirror pieces.
  1. Kilt CLEARANCE (round 2)
    By RockyR in forum USA Kilts
    Last Post: 4th December 08, 12:57 PM
  2. Round Brass Kilt Buckle
    By LordKiltClad in forum How to Accessorize your Kilt
    Last Post: 9th August 07, 06:37 PM
  3. Gather 'round...
    By Mike1 in forum General Kilt Talk
    Last Post: 16th November 06, 12:31 AM
  4. X-Kilt protype #3, 'round the authors bum
    By Alan H in forum Show us your pics
    Last Post: 19th August 06, 06:21 AM
  5. Gather 'round
    By Mike1 in forum Show us your pics
    Last Post: 12th May 06, 10:31 AM
