Results 1 to 10 of 26
    16th September 09
    Toronto, Canada
    leather shoe resuscitation
    I found a pair of nice, cap toe, leather sole, black oxford, dress shoes at a thrift store the other day and am planning out how to revive them. Please offer any advice you might have on the subject of leather dress shoe care and maintenance!
    These shoes are worn but definitely serviceable. My biggest concern is a wee bit of cracking in a couple places...
    Here's what I'm thinking so far:
    1) Clean with either a damp cloth or saddle soap
    2) Condition the upper with mink oil or some other leather conditioner
    3) Seal the leather soles with dubbin
    4) Shine with coloured cream or wax polish
    Now I just need to hope Santa gets me some shoe care products for xmas including cedar shoe trees...
    - An t'arm breac dearg
    25th December 08
    Lotus Land
    An old toothbrush does well for getting into those tight corners whether you are cleaning out or polishing on.
    I suspect mink oil is your friend for the cracking. I always use Kiwi brand polish and spit shine.
    5th November 08
    Marion, NC
    Attention please! Calling DFWII!
    (He's our resident shoemaker.)
    --dbh
    16th September 09
    Toronto, Canada
    I'm hoping Artificer might chime in too...
    14th July 08
    Memphis, TN
    Dr. Jackson's Hide Rejuvenator is pretty good stuff. But anything you put on them has the potential to darken the leather a bit. If you can live with that, go for it.
    http://www.tandyleatherfactory.com/s...kw=Dr.+Jackson
    16th September 09
    Toronto, Canada
    Quote Originally Posted by budd4766 View Post
    I think I'm definitely going to need something like that. Darkening the leather should be fine though; the shoes are already black!
    5th August 08
    Lancashire, England
    Kiwi Polish, vigorously and repeatedly applied with a stiff "on" brush and a soft-ish "off" brush. Just keep working it in... It's worked for every pair of manky boots I've ever had.
    3rd March 10
    43*N 88*W
    You rang?
    While not a shoe maker, I have done a bit with leather over the years. Shoes are somewhat unique in that certain areas bend CONSTANTLY. To a certain extent, the amount you should try to rejuvenate depends on just how dry the leather is.
    Truly dry leather should be left alone, don't attempt to re-hydrate or it will swell and crack (it's basically mummified).
    If the leather is still pliable and hasn't gotten to 'carded' (stiff and cardboard-like) you might want to consider neatsfoot oil, or neatsfoot blended with mink to help re-hydrate- a few treatments over a week or so before you plan on trying to polish and wear.
    Then, instead of Kiwi paste polish, I'd try the Kiwi CREME polish HERE. It will help prevent the leather drying out a bit more than the paste will.
    Also, don't wear them for a full day right away. You'll likely have to break the leather in again and re-soften them. If you wear them too much right at first you might aggravate the cracking problem or cause a tear in the leather.
    To help disguise the cracking when you do polish, mix a bit of melted beeswax with the polish and use it to fill any gouges or scaling. Once it dries and hardens you can polish over it just like the leather. This DOES NOT work when the cracking is in the 'flex' are across the top of the toe/ball of foot area, as it flexes too much and the fill will work loose.
    16th September 09
    Toronto, Canada
    Quote Originally Posted by xman View Post
    Quote Originally Posted by English Bloke View Post
    You rang?
    <snip>
    Kiwi seems to be the go-to brand, eh? I've got an old tooth brush for polishing but will put a soft-ish "off" brush on my list...
    Here's a couple "before" pictures. Luckily the leather isn't too badly dried out... the cracks are just behind the toe cap, where the instep flexes.
    Kerrville, Texas
    I absolutely agree. But I seem to recall reading somewhere that before attempting this, one should clean off the surface with rubbing alcohol (I think it was, anyway). This removes existing wax and such, allowing more uniform penetration of the oil into the grain of the leather.
    Basically it 'unseals' the leather before oiling, and then you 'seal' it back with the polish afterwards.
    What say the experts on this? Is the step with alcohol recommended, or is it superfluous?
  1. 10 Day Shoe Sale
    By Chas in forum How to Accessorize your Kilt
    Last Post: 15th December 09, 06:01 AM
  2. Shoe/Boot Help
    By macstig in forum Kilt Advice
    Last Post: 26th July 07, 10:13 PM
  3. Shoe Buckles
    By pipesndrumsnun in forum How to Accessorize your Kilt
    Last Post: 18th July 07, 08:38 AM
  4. Shoe Accessory
    Last Post: 31st January 06, 08:21 AM
  5. Shoe Question
    By Hal in forum Kilt Advice
    Last Post: 1st April 05, 01:24 PM
