Results 1 to 7 of 7
    5th September 10
    Louisiana
    Single Width-,Double Width
    Can someone here begin to discuss the details between single width and double width material. I saw an advertisement for the first time mention the making of custom weave tartan in single width. I am assuming its much like two ply toilet paper.
    25th December 08
    Lotus Land
    Single width is usually about 27" wide, from selvedge to selvedge. Double width is, well, double that, so 54".
    2nd May 10
    Roseville, California
    tartan width
    As X has stated it is relative to the width of the fabric not, as in the case of toilet paper ply, the thickness.
    Therefore, you would need half as much double width fabric to make the same yardage kilt as you would in single width. The benefit of double width is that it is not typically twice the price, but rather, just a little more than single width. For example single width may be $30 per yard wherein double width will be $35 per yard (these numbers are for comparison only).
    Some tartans are only woven in one width or the other.
    Some retailers, such as Heritage of Scotland, sell all material calculated at the the same price regardless of which width it is woven in. In other words, they will send you 8 yards of single width (if that is the only width a particular tartan is woven in) for the price of 4 yards double width.
    Hope that helps.
    Brooke
    5th September 10
    Louisiana
    Thanks...understood.
    2nd January 10
    Lethendy, Perthshire
    17 Post(s)
    Quote Originally Posted by MacMillan's son View Post
    This of course only applies to stock tartans.
    Any tartan can be woven in either width but they'll not necessaritly be avilable off-the-shelf.
    For non-stock tartan the minimum order for double width is generally a half piece- 30 yards, whereas non-stock single width is avialable from 4 yards upwards. As with most things commercial, the more one buys, the cheaper it gets.
    3rd August 09
    Fayetteville, North Carolina
    One additional detail...
    I believe you got the answer you were looking for...but the other thing I felt the need to add is that double width fabric has a kilting selvedge on both edges, whereas single width fabric will have one edge with a kilting selvedge and the other with a less finished selvedge...because when you rip it to width, you're going to rip that edge off anyways.
    25th December 08
    Lotus Land
    Quote Originally Posted by longhuntr74 View Post
    ... double width fabric has a kilting selvedge on both edges, whereas single width fabric will have one edge with a kilting selvedge and the other with a less finished selvedge....
    Unless it is woven on a 27" loom. Then there will be two selvedges.
  1. "Single Width" Fly Plaid?
    By Cygnus in forum General Kilt Talk
    Last Post: 29th June 10, 03:46 AM
  2. I have 13 oz. double width 100% pure worsted wool!!
    By keepoffgrass in forum Kilt Advice
    Last Post: 3rd October 07, 10:18 PM
  3. belt width for different kilts?
    By apack in forum Kilt Advice
    Last Post: 7th August 07, 04:00 AM
  4. Belt width?
    By Nick in forum How to Accessorize your Kilt
    Last Post: 9th March 06, 08:24 PM
  5. Nap runs the length not the width
    By Anthony in forum General Kilt Talk
    Last Post: 10th November 04, 10:40 AM
