24th June 11, 08:55 AM
Cthulhu Box pleat
Thinking of getting a Black 6yd Box Pleat with Cthulhu Tartan inserts. How much Tartan would I need?
I like a nice short parade that ends at a bar.
24th June 11, 09:01 AM
It will depend on how many box pleats you will have, and whether you want the same portion of the new tartan in each reveal,so if you have 12 box pleats you would need 13 portions of tartan, at least and if the sett is say 7 " you would need (13x 7 ) 91" of single or about 45" of double but that would be a minimum, I would allow a but extra just in case!
Speak to your kilt maker just to check!
24th June 11, 09:13 AM
it is an 8" sett. Hopefully this will aid in calculation.
24th June 11, 09:20 AM
This may sound overly simple, but if you are wanting a "6yd box pleated kilt" as you describe, then you'll need 6 yds of single width cloth (or 3 yds double).
24th June 11, 09:24 AM
He means for it to be black, with tartan only in the pleats, if I'm reading it correctly.
ith:
24th June 11, 09:25 AM
Jaeson is actually wanting a 6 yd box pleated kilt with "inserts" of the tartan, not a complete kilt!
24th June 11, 10:20 AM
How do you sew the inserts to the box pleat?
24th June 11, 10:56 AM
No idea, but the concept does fit with the nature of the tartan itself as being both alien and inimical to the natural order of our universe.
24th June 11, 11:12 AM
Dale Seago nailed it, yes a Black Box Pleat with Cthulhu Tartan inserts
24th June 11, 11:27 AM
The way I did it on my x-kilt was to make the outer portion of the pleat, and the arm going to the back piece, and have a seam with the back part at what would be the interior folds in the pleat. I can try putting up pictures after I am home, if you would like.
By CDNSushi in forum Miscellaneous Forum
Last Post: 19th August 13, 04:32 AM
By Calico in forum Kilt Advice
Last Post: 22nd June 11, 02:05 PM
By iustus in forum Traditional Kilt Wear
Last Post: 2nd August 10, 09:07 PM
By herminator in forum Miscellaneous Forum
Last Post: 6th May 09, 10:01 PM
By wsk in forum The Tartan Place
