Results 1 to 3 of 3
    28th June 11
    Berkshire, UK
    Casing leather help
    Bit confused about casing leather.
    How much water should it take to 'case' the leather?
    Is it one wipe over with a damp sponge or are you trying to saturate the leather?
    Martin.
    AKA - The Scouter in a Kilt.
    Member of the Clan MacLeod Society (Scotland)
    3rd March 10
    43*N 88*W
    Re: Casing leather help
    True casing is actually a two step process.
    The hide should be soaked until the small bubbles are seen bleeding out of the skin, THEN the hide should be stored for ~12 hours in a 'case'. Originally this was a steel lined box, you can use a mostly (but not entirely) sealed tupperware container. This allows the water to fully penetrate the hide (to achieve the best plasticity and evenness) but for any excess to start to evaporate.
    If you're not doing incredibly fine tooling you can probably get by giving the leather a decent soak with a VERY wet sponge, letting it set for a while to penetrate and even out, then tooling.
    HERE'S
    a pdf from a very well-known tooler with some guidelines.
    ith:
    28th June 11
    Berkshire, UK
    Thanks. Makes interesting reading.
    Now to start practicing on scraps so I can finish my latest sporran project.
    Martin.
  1. Leather Jackets with Leather Kilts
    Last Post: 22nd March 11, 09:34 AM
  2. Leather?
    By Jerry in forum Miscellaneous Forum
    Last Post: 15th July 10, 04:51 AM
  3. Leather
    By Nighthawk in forum DIY Showroom
    Last Post: 16th April 09, 08:03 PM
  4. Leather Questions (Tandy/Leather Factory)
    By Cat in forum DIY Showroom
    Last Post: 23rd February 08, 02:40 PM
  5. how much leather
    By Scottishrebel in forum DIY Showroom
    Last Post: 28th January 07, 10:13 PM
