Results 1 to 3 of 3
    19th May 11
    Albuquerque, New Mexico, USA
    Utilikilt Under Apron Fix
    Tobus posted about a year ago about the under apron getting between his legs on Utilikilts. It happen with about a third of mine. When it starts to annoy me, I use iron-on HD hemming tape between the first and second layers, then put an iron on patch over the top of all from the back side.
    It gives this edge three layers of bonded fabric for stiffness along that left edge and no leg diving.
    I did bend the left edge out/down while it was still hot from the iron.
    The triangle patch is the only one associated with this fix.
    The pictured squares plus 5 more not pictured are due to their edger not working correctly when they made this one - made Nov 2010, bought from Utilikilt Dec 2011. Passed my inspection upon reciept and became evident after first wash. Luckily the edger was working when they edged the bottom - LOL.
    UPDATE - I went through about half Of my Utilikillts checking. This seems to be needed more on the longer or more flexable kilts I have. I think it is the weight of the fabric at the left edge that is pulling the under apron into a tendancy to curl under. I have done this to all of my long (23 inch) Workmans Duck and denim and to both shorter denim Workmans. And to one of my Survivals, the Desert Digital in really light weight cloth. I didnt realize how many had gotten the treatment - I only do it if it is buggng me - I take it off, warmup the iron and fix it, put it back on and forget it.
    Kerrville, Texas
    Re: Utilikilt Under Apron Fix
    Hmm... interesting fix! I'm going to have to chew on this for a while, look at my Utilikilt, and make sure I understand exactly what you did. But it may just be the trick for getting rid of that slightly annoying issue. Well done, sir!
    19th May 11
    The first step of putting the hem bonding tape in between the fabric layers - where the scissors are - and bonding the two layers with the iron may be all that is needed. If not, buy a denim or twill knee patch of the desired color (won't show - LOL) and cut it into two right triangles with the angle the same as the row of snaps. I use one now and the other for the next fiesty Utilikilt. Place it as pictured close to the left edge and 1/4 " away from the snaps and iron it down. While still hot I bent the left hem out at a 45 degree angle to help guide the apron onto my left thigh rather than stabbing it.
  1. Under Apron Hem?
    By Farlander in forum Professional Kiltmakers Hints and Tips
    Last Post: 3rd April 10, 08:41 AM
  2. A Wider front apron than a Utilikilt...?
    By CDNSushi in forum Contemporary Kilt Wear
    Last Post: 21st April 09, 04:46 PM
  3. My very own Kilt apron!!!
    By Arlen in forum How to Accessorize your Kilt
    Last Post: 22nd February 09, 06:16 AM
  4. Apron when sitting
    By AckZel in forum General Kilt Talk
    Last Post: 12th January 06, 07:54 PM
