Results 1 to 4 of 4
    1st December 11
    Gettysburg, Quaekelinink(PA in Delaware)
    Question Garter Tie Manes
    I have had garter ties for some time now that I purchased from Scottish Trading Company. Since then I have noticed that many ties worn by others seem to have the fringes bobbed; any road, they're shorter than mine. I am wondering if I was supposed to shorten them myself. They seem to be a little shy of the length touted by other vendors and thus I always use the most basic tying method to get them around my calf (and I have slim calves) just to have some fringe showing. It feels a tidge trivial, but I'd rather not be doing the garter tie equivalent of leaving basting stitches in my pleats
    Advice is most appreciated.
    M. A. C. Newsome is offline
    INACTIVE
    Contributing Tartan Historian
    26th January 05
    Western NC
    Re: Garter Tie Manes
    Blake,
    Pictures might help. Did they look like these when they came to you?
    http://www.scottishkilthose.com/trad...l_garters.html
    I would not normally expect there to be any after-market work you have to do with your garters, they should be just fine to wear as they are. How long is the fringe on yours?
    17th September 11
    Erwin, TN, USA
    Maybe the issue isn't from the garter length, but from the turn-down size of the hose?
    Also, here's a video by someone *points up* on how to tie them: http://www.youtube.com/watch?v=9h08uYRMx7A
    1st December 11
    Mr. Newsome,
    As the saying goes, a picture's worth a thousand words. The fringes on my sets seem to be double the length of the ones from the trade photo you've linked. When I wear them, if I don't tuck some up into the cuff, it puts me in mind of the feathers on a draft horse. When I see other pictures of ties worn, there usually is a bit of the un-fringed part peeking out just under the cuff line-or in shots of those in Hunting breeks, a goodly portion of the tie is visible.
    Measuring them now the solid bulk of the tie is 29 inches with each fringe being 3 to 3and 1/2 inches long themselves on either end. If I recall correctly, name brand ties run about 36 inches, which explains why I can't use but the simplest wrap and tuck method with these.
    To rlloyd:
    I have noticed that too, especially the difference between common hose with the diamond cuffs and regimental hose (like from WPG) where the cuff is supposed to be very wide. I actually like the wider, but as the diamond cuff type are so available I have more of those. When I put them on, I usually end up double folding them. Believe you me, when I bought my ties I watched all the instructional clips from the museum over and over.
  1. How to Tie a Traditional Garter Tie
    By McMurdo in forum Putting It On Properly
    Last Post: 15th May 09, 06:26 AM
  2. And how to tie a snake garter ?
    By Rollo in forum How to Accessorize your Kilt
    Last Post: 2nd April 09, 09:43 AM
  3. How do you tie your Garter ties
    By scotchmaster in forum How to Accessorize your Kilt
    Last Post: 2nd April 09, 05:10 AM
  4. Garter Ties!
    By Rob Wright in forum How to Accessorize your Kilt
    Last Post: 30th March 09, 11:01 AM
