Results 1 to 10 of 33
    9th August 16
    Southern Highlands, New South Wales
    Adjustments for ladies' kilts/kilt skirts apron/underapron sides
    Quick newbie question, if that's okay.
    To make a short kilt for my wife, if I wish to observe the rather arbitrary convention that ladies' kilted skirt aprons wrap with the apron edge/fringe to the left rather than the right, is the only change necessary the swapping of buckle/buckle hole sides, or must I make the deep pleat and the inverted pleat on opposite sides too? Apart from making the buckle hole in the second last pleat, wouldnit affect the marking out of the kilt as well? When I wrap my own kilt rift over left, only the buckle side seems relevant.
    What say ye?
    4th August 06
    rison, arkansas
    I'm sure somebody with way more sewing knowledge than me (doesn't take much for that) will soon chime in but if I'm reversing the opening I'd reverse the construction also.
    I will say unless it bothers her to have the opening on the "wrong" side I'd be tempted to just make it normal except for the desired length.
    Knowlege is knowing that a tomato is a fruit; Wisdom is knowing not to put it in a fruit salad
    Quote Originally Posted by Dreadbelly View Post
    If people don't like it they can go sit on a thistle.
    Unless your lady likes the idea of wearing 4 pounds of wool around her waist may I comment that, in general, a man's kilts will often be made quite differently than a ladies Tartan pleated skirt.
    A skirt for a lady will usually be made with lighter fabrics. 10oz if the most common.
    Skirts will usually be made with less fabric. The pleats are usually shallower. Box pleats are quite common to reduce the amount of fabric.
    Tartan skirts will also be made more like other skirts. This means that they usually do not have the internal construction elements found in a man's kilt.
    Externally a skirt can open on the left or the right. This is a personal preference thing.
    The size and shaping of the aprons can be the same as for a man. Again, personal preference. And what looks best on each person. Girls have different shapes than us guys.
    I personally think box pleats are very flattering to the female shape. Box or knife is another personal preference thing.
    A man's kilt is a very complex garment. A ladies Tartan pleated skirt is usually made following the pattern of other skirts.
  4. The Following User Says 'Aye' to The Wizard of BC For This Useful Post:
    tpa
  5. #4
    9th August 16
    I bought 11Oz fabric (with selvedge) for my daughters but the tartans my wife wanted were not available in that weight, so I got 13Oz for her. She wants a knife pleated skirt as she feels that box pleats make her look fat, accentuating her 27.5"/40" waist/seat ratio. Some of the short ladies' kilted skirts that Howie Nicholsby makes are her guide. I was going to use about 5 yards.
    So in construction, the way the apron sits slightly forward (to make the triangular shape from the front) doesn't matter whether it emerges from a deep pleat or inverted pleat? Is that right?
  6. #5
    The deep pleat of a kilt serves two functions. It gives a little more fabric behind the apron allowing them to drop between the legs naturally.
    It also allows the sides of the apron to fall correctly. You can usually see a poorly made deep pleat in aprons that gape open at the bottom.
    A Reverse pleat is just another deep pleat on the opposite side where the pleats are in the other direction.
    So yes, if you make the skirt like a kilt you have both deep and reverse pleats. These will be just like their name implies - deeper than a normal pleat. How much deeper you ask? Well, that depends on the kiltmaker, and the layout of the aprons.
    And I'm not sure what you mean by "the apron sits slightly forward". The apron should fall straight down from the top of the kilt in the front. The side edges should fall straight down and be aligned with the pleats.
  7. The Following User Says 'Aye' to The Wizard of BC For This Useful Post:
    tpa
  8. #6
    4th November 16
    US
    Okay, based on numerous photographss of kilted skirts I've seen, and one in my possession, it would seem typical for the knife pleats to go in the same direction as on a men's kilt. So if the apron opens on the left instead of the right, the reverse pleat is at the edge of the outer apron. As for a deeper pleat on the other end, well, that's harder to discern from photos, and the inner apron edge on the PV mini kilt from Scotweb that I have is no deeper than the other pleats.
    And like Steve said, they tend to be structured much more simply than actual kilts. So with less fabric, pleating to the sett is not typically an option. Here's a kilted skirt (or I suppose a cilted sgert, since it's a Welsh tartan ) that I made based on the above-mentioned mini kilt:
ID:	30147 Click image for larger version.
    You can see the reverse pleat in the first pic. And while at first glance it may appear to be pleated to the sett, note on the apron how the red-striped burgundy band is bordered by the smaller red stripes while the blue-striped one is bordered by the smaller black bands, but it's the other way around on the pleated portion. I also had to add darts to the upper apron, since too much of the sett would've been lost if I'd just tapered the edges naturally; indeed, perhaps the greatest challenge in making kilts for women (or in my case, dolls*) is preserving the pattern on the fell with the more pronounced taper of a typical female form.
    * In case you didn't figure it out already, my username is a portmanteau of "doll" and "Highlander".
  9. The Following User Says 'Aye' to Dollander For This Useful Post:
    tpa
  10. #7
    My knowledge of kilts is, I suspect, coloured by the impact of the two world wars here in the UK. Possibly other people were influenced too
    There was rationing of fabrics and clothing.
    As the years wore on and garments wore out there was a real shortage of warm sturdy garments. Women used anything they could find to convert into garments, clothes rescued from dressing up boxes, amateur dramatic costumes - and there were kilts. As a kilt with the pleats cut out would not be of much use if taken apart, most were probably worn as they were.
    I had kilts as a child, and they were fastened on the right - but that was considered normal.
  11. #8
    5th August 14
    Oxford, Mississippi
    Look to Lady Grey's photos for a woman's ability to wear a kilt. She offers views of solid design, style and whimsy. She presents my opinion of new representations to old ideas.
    I must also mention Angie Bodine's ability to "spark and dazzle" with her collection and sense of fashion.
