Results 1 to 10 of 14
    Highland regiments sporran chart
    As we know only five kilted Highland regiments survived the 1809 reassignments: the 42nd, 78th, 79th, 92nd, and 93rd Foot.
    Under the 1881 Cardwell reforms these became
    The Black Watch
    The Seaforth Highlanders
    The Cameron Highlanders
    The Gordon Highlanders
    The Argyll and Sutherland Highlanders
    Their sporran traditions are a bit confusing because they weren't consistent from regiment to regiment.
    For example in some regiments officers wore the same sporran for Full Dress and Levee Dress while in others they didn't.
    Being the visual person that I am, I decided to come up with a chart of sorts, showing the situation according to the 1911 dress regulations.
    The regiments are shown in the above order.
    The right three columns are commissioned officers.
    I've not included the Pipes & Drums and Military Band sporrans except when these overlap with others. (Most regiments had dedicated pipers' sporrans, not shown here.)
    Here's each column labelled. Unfortunately the add-text site also reduced the image size.
    The Camerons made do with two styles while the Argylls required four, having a completely different sporran for certain Senior Sergeants such as the Drum Major, Pipe Major, Colour-Sergeant, and I'm not sure who all else.
    6th May 10
    socal
    thanks
    pretty interesting
    22nd July 08
    Moscow, Russia
    about Gordons NCO sporrans
    John Malcolm Bulloch in "The Gordon Highlanders Uniform" in the "Journal of the Society for Army Historical Research", Vol. 15, No. 59 (Autumn, 1936) writes that the members of the Sergeants' Mess wear the same pattern of sporran top as the officers, but without the outermost band of engraving.
    I have never seen such cantle...
    22nd July 08
    Moscow, Russia
    Dear OC Richard, I think the highlighted sporran is specific only to the drum major, another similar sporran with 3 tails is unique to the pipe-major, the rest SNCOs wore the standard badger head sporran.
    Quote Originally Posted by blackwatch70 View Post
    It's a messy situation which I don't fully understand. Here's the two-tassel DM and three-tassel PM as you point out.
    The Colour-Sergeant also wore two tassels
    The messy part is that there was a second type of cantle as well. That boxy cantle at some point was replaced by this one, similar though not identical to the common cast-thistle cantle that's become ubiquitous for civilian horsehair sporrans.
    What I don't know is if it's a 1st Battalion/2nd Battalion thing. As we know in the period immediately following the 1881 amalgamations the non-kilted Battalion of each pair would have to acquire the kit of the kilted Battalion.
    But since both Battalions already had Pipes & Drums some items of pre-amalgamation kit continued to be worn. (The Seaforths never did put both Battalions' pipers in fully matching kit.)
    So I don't know whether or not the boxy cantle and rounded cantle survived side-by-side in the two Battalions, but it can be seen that eventually the boxy cantle was discontinued and both Battalions ended up wearing the same rounded cantle.
    In 20th century photos both the Pipe Major and Drum Major are seen wearing the same three-tassel rounded-top sporrans, however from the photos I've seen the white sporran only survived for these two positions, no longer worn by the Colour Sergeant and whatever other Senior Sergeants might have worn it in Victorian times.
    (Note that the DM above's cantle is not the traditional Argylls pattern, but the common civilian pattern, which by the way was later adopted by certain other regimental pipers in modern times.)
    22nd July 08
    Moscow, Russia
    The Drum Major on the left and the Colour-Sergeant between the Colours is the same guy that's why sporran is same.
    22nd July 08
    Moscow, Russia
    I suppose, the round top of sporrans with 3 tassels for Drum- and Pipe Majors were characteristic of the 1st Battalion from the beginning, that's why they remained after 1948, when both battalions were amalgamated.
    The PM of the 1st A&SH is on your photo, just compare to 2nd A&SH, PM William Robb below.
    Thanks for that photo! I'd not seen that one.
    Here's a pre-amalgamation photo, I'm supposing it's the Pipe Major of the 93rd Foot.
    Here's the Pipe Major (far left) and pipers of the 91st Foot in 1872, which became 1st Battalion Argyll & Sutherland Highlanders in 1881.
    The PM looks like he's wearing the same crossbelt hardware as the 1st Battalion PM above.
    I don't have a clear photo of the Pipers' sporran cantle, in this painting it just might be the same cantle which is later seen worn by the PM and DM of the 2nd Battalion Argyll & Sutherland Highlanders.
    It makes sense, to keep the same sporran but change from six short tassels to three long ones. (The holes would already be in the right places.)
    Question is, when the rest of the 2nd Battalion pipers got the grey sporrans, were they two-tassel, or three? I've seen old photos of Argylls pipers wearing both sorts.
    22nd July 08
    Moscow, Russia
    Yes You are correct, this is pre-amalgamation photo of the Pipe Major of the 93rd Foot.
    Here is detailed photo of Piper 1st A&SH some time after amalgamation, he's wearing new regimental collar dogs but old 91st pipers uniform.
    Sure You have seen this photo...
    22nd July 08
    Moscow, Russia
    I think pipers of both battalions were officially supplied grey sporrans with 3 black tassels just after amalgamation 1881 but as we can see pipers of the 1st Battalion still wore old pattern sporrans some time (I suppose because in 1881 the 1st Battalion served in South Africa whilst the 2nd Battalion remained in the UK until 1892 and it is obvious that in this case of abroad battalion changing small elements of the uniform could take a long time).
    One more 1st Battn piper (ex 91st ) still wearing 91st pattern dirk but new sporran.
Name:	1st+Argyll+&+Sutherland+Highlanders+pipers+wearing+the+old+91st+Highlanders+dirk+.jpg
    Pipers of 93rd probably wore 2 tassels sporrans before 1881 amalgamation
    and changed to 3-tassels just after.
